06-25-2016, 06:17 PM | #81 |
Re: 30 Zenith Carb
Ok will do. Its getting to the point I can take this stuff with my eyes closed..
Cheers |
06-25-2016, 09:56 PM | #82 |
Re: 30 Zenith Carb
Bill your answer is 20 miles away. Take the beast to White Post restorations and for a few dollars and a years wait you will have solved the problem!
We had the car running daxx good for twenty minutes the other day until the gas ran out of the auxillary tank. I told him to remove the shut off valve and when he told me all looked clean I thought we had tamed the beast. When I got home I put the carb I loaned him on my coup and with no leaks it started right up and I went for a ten mile trouble free ride. I'm getting frustrated as is Bill but I AIN'T giving up. I know a good local carb man who can do what Vince suggested and pass this on to Bill. this post is getting to the point where it's good summer reading Sewall |
06-25-2016, 10:55 PM | #83 |
Re: 30 Zenith Carb
"We had the car running daxx good for twenty minutes the other day until the gas ran out of the auxillary tank."
Then how can it be carb problem?? "When I got home I put the carb I loaned him on my coup and with no leaks it started right up and I went for a ten mile trouble free ride" Then how can it be a carb problem?? Information is being gained from a diagnostic maneuver, but you are taking those results and going somewhere else with the information you are getting. I don't understand.
'31 180A |
06-26-2016, 03:48 AM | #84 | |
Re: 30 Zenith Carb
06-26-2016, 03:50 AM | #85 | |
Re: 30 Zenith Carb
Or a thanks for the offers Last edited by Mitch//pa; 06-26-2016 at 04:58 AM. |
06-26-2016, 08:26 AM | #86 |
Re: 30 Zenith Carb
06-26-2016, 09:00 AM | #87 |
Re: 30 Zenith Carb
I suggest trying a different ignition coil. They can do some strange things when they are failing.
Doug in Waterloo |
06-26-2016, 09:11 AM | #88 |
Re: 30 Zenith Carb
Mitch, just toss a few tools in the back of the truck and head on over there and get'er done. The barners will chip in for your service charge. Today would be a good day, your shop is closed on Sundays, any way. That will be less than 400 miles on the road, and 10 minutes to fix it, so road time of 6 hrs at 60 mph, shop time minimum 1 hr, so your rate times 7 hrs, and he won't have to give the car up
'31 180A |
06-26-2016, 09:31 AM | #89 | |
Re: 30 Zenith Carb
06-26-2016, 09:57 AM | #90 |
Re: 30 Zenith Carb
He is learning. Sometimes it gets discouraging on both ends when something is being taught.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. Last edited by 30ccpickup; 06-26-2016 at 10:33 AM. |
06-26-2016, 10:03 AM | #91 |
Re: 30 Zenith Carb
Hey Hey guys. Despite not responding to each post let me state I really appreciate and thank everyone for their input.
This has gotten to the point I seem to be playing the fool. Therefore, until I stumble across the solution I think it best I refrain for any further posting on this problem. Again my gratitude for the encouragement and suggestions. Bill K |
06-26-2016, 10:16 AM | #92 | |
Re: 30 Zenith Carb
06-26-2016, 01:50 PM | #93 |
Re: 30 Zenith Carb
Bill, we need your feedback to figure out the problem. Or should I say the solution to the problem.
07-05-2016, 04:44 PM | #94 |
Re: 30 Zenith Carb
It's ALIVE It's ALIVE. To make a long story short I took the bottom plate off the dist. I noticed the Bus Bar (I guess you can call it that) had a round hole which lined up with the condenser but it was not connected to the condenser therefore taking it out of the circuit. Connected it back up, started it up and drove (for the first time) 5 trouble free miles, no hint of coughing back through the carb.
I replaced the float valve also and got the float level correct which was not that far off. My daughter volunteered to ride along and the first thing she said Mom keep your cell on so we can call for help.. So far so good, I'll take a longer trip tomorrow to satisfy myself. Again thanks for all the help on the forum. Really appreciate it |
07-05-2016, 05:10 PM | #95 |
Re: 30 Zenith Carb
Bill, Glad you found the problem. Did you put that fiber washer between the screw and condenser? If not, it might short to the body of the distributor.
1930 Pickup in Prior Lake, MN |
07-05-2016, 05:21 PM | #96 |
Re: 30 Zenith Carb
Yep - thanks
07-05-2016, 05:36 PM | #97 |
Re: 30 Zenith Carb
I refer you back to posts #2 & #15.
07-05-2016, 06:22 PM | #98 |
Re: 30 Zenith Carb
07-05-2016, 06:27 PM | #99 |
Re: 30 Zenith Carb
I also shall never forget the words of wisdom which reminded me "most carb problems are electrical All I can say I did not know much about my A but after this we are intimate......
07-05-2016, 07:50 PM | #100 |
Re: 30 Zenith Carb
Just glad you got it fixed, Bill. We want our cars running for the summer!
