Old 06-05-2016, 11:35 AM   #1
William Kelchner
William Kelchner's Avatar
Default 30 (?) Engine #
Any info on the following engine number A322353 ? No * at either end of the number. Thanks
William Kelchner is offline   Reply With Quote
Old 06-05-2016, 11:39 AM   #2
Russ/40
Russ/40's Avatar
Default Re: 30 (?) Engine #
Likely a restamp by prior owner.
Russ/40 is offline   Reply With Quote
Old 06-05-2016, 02:40 PM   #3
1931 flamingo
1931 flamingo's Avatar
Is it a "diamond" block??
Paul in CT
Old 06-05-2016, 03:39 PM   #4
William Kelchner
Paul in CT
Let me take a look - according to the search on here there should be some sort of casting mark on the lower right of the block correct?
Old 06-05-2016, 04:07 PM   #5
William Kelchner
Unhappy Re: 30 (?) Engine #
Hard to check for any other casting marks, car is on rollers and blocked in the garage by my other old vehicle, I can't wiggle my old body into the right position . The A has not been driven for about 10 months. I'll be taking it out soon for a local Fathers Day show and take a look then. At any rate it appears that there is really nothing to identify this engine. Thanks anyway
