Old 10-09-2021, 11:00 AM   #1
WRA
WRA's Avatar
Default Model B Parts Vendor
Who are you “Go To” vendors for the basic Model B parts.
Having a hard time finding Things like rear main drain tube, oil fill/breather tube, etc.
WRA is offline   Reply With Quote
Old 10-09-2021, 11:24 AM   #2
Dan McEachern
Default Re: Model B Parts Vendor
All Ford Parts Campbell, CA
allfordparts.com
Dan McEachern is offline   Reply With Quote
Old 10-09-2021, 11:59 AM   #3
Charlie Stephens
Try placing a "wanted ad". The parts you are looking for are more likely to be under someones bench instead of with a vendor.
Charlie Stephens
Old 10-09-2021, 05:57 PM   #4
DavidG
DavidG's Avatar
Snyder's in Ohio (snydersantiqueauto.com) carry a fair number of B parts including the rear main bearing drain tube. They offer a oil filler tube with the baffles as original, but it is the Model A version. The early Model B oil filler tube is the same diameter as the Model A tube, but the B version is longer and somewhat scarce. The late Model B oil filler tube's upper diameter is much larger as is the cap used with it. I do not believe that either B tube was ever reproduced, but the later, larger type is not the least bit rare. Try Michael Driskell at Third Gen Auto for an original of either type.
Old 10-10-2021, 07:40 AM   #5
WRA
WRA's Avatar
DavidG, thanks for the leads, I’ll look into this
Old 10-10-2021, 09:18 AM   #6
DavidG
DavidG's Avatar
You're welcome.
