Old 09-26-2019, 12:06 PM   #1
Planojc
Planojc's Avatar
Default 30-31 wheel well patch panel question
Was the L shaped flange on the bottom of the panel folded up to the sub rail or left L shaped? Thanks
Planojc is offline   Reply With Quote
Old 09-26-2019, 12:19 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 30-31 wheel well patch panel question
It was actually scalloped in several areas and was spot-welded to the Sill (Sub-rail).
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-26-2019, 10:20 PM   #3
Wallringo
Wallringo's Avatar
Post a picture of what your referring to.
Wallringo is offline   Reply With Quote
Old 06-09-2020, 09:28 PM   #4
Roadster62
Roadster62's Avatar
BRENT, Does someone make a "Correct" patch panel than has rolled beads that match factory beads. I want to repair mine, no desire to use the overlay full panel. If someone can roll a factory correct center bead on a 12x12 piece of steel that is another option. Thank you. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 06-10-2020, 10:05 AM   #5
BRENT in 10-uh-C
Bob, not that I am aware of. Since you mentioned beading, I'm gonna assume you are working on a Coupe or Roadster. If it is a Roadster, the closest company that I can think of that might get you close would be Brookeville. Maybe they would have a 2nds quarter panel you could purchase. Outside of that, you will probably need to fabricate it yourself.
BRENT in 10-uh-C
Old 06-11-2020, 12:06 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I folded the L shaped flange at the bottom of the wheel well patch panel up to the sub rail . I felt that it was necessary .
