Old 01-02-2021, 08:45 PM   #1
drolston
drolston's Avatar
Default '34 Pickup Windshield Rattle
Annoying clatter from the top of the windshield. Once the speed is up to 40 mph or so, it goes away. Does not happen with windshield swung out to the first notch. Tried a foam strip; - no help.
Ideas?
Old 01-02-2021, 10:14 PM   #2
Brian
Brian's Avatar
Default Re: '34 Pickup Windshield Rattle
Ideas? Dunno, remove wiper blade and arm, see if the noise is still there. Process of elimination begins....
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-02-2021, 10:34 PM   #3
325w
Use some blue painters tape around the frame and the glass. Glass maybe rattling in the frame.
325w is offline   Reply With Quote
Old 01-03-2021, 02:35 PM   #4
drolston
drolston's Avatar
Aha! Why didn't I think of that. I will give it a try and report back.
Old 01-04-2021, 03:44 AM   #5
fourfords
fourfords's Avatar
I had the same problem on my Model A. I injected motor oil into the windshield frame. No problem for 20 years.
fourfords is offline   Reply With Quote
Old 01-04-2021, 09:47 AM   #6
hop up
hop up's Avatar
Are you sure its the windshield as my noise was coming from the door hinge but did sound like the window frame.
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 01-04-2021, 12:43 PM   #7
sidevalve8ba
sidevalve8ba's Avatar
Yes, I had a rattle in my '32 pickup that I thought was the windshield and, like you say, turned out to be a door rattling.
sidevalve8ba is offline   Reply With Quote
