09-23-2017, 10:02 AM | #1 |
Valve problem
I have an issue with an exhaust valve that just started sticking. This is a new build that has about 30 miles on it. Has been running great. At 1500 rpm, the lifter starts clattering and the engine misses. I can goose it and it quiets down. No noise at idle. Ran a compression check this morning and all cylinders are 120 psi. Temp runs at 150 degrees. I need some suggestions on this one.
Thanks, Ed |
09-23-2017, 11:31 AM | #2 |
Re: Valve problem
Alittle MMO in the gas and use 180 stats. Flathead should run hot.
09-23-2017, 12:23 PM | #3 |
Re: Valve problem
I agree, 150 is too cold.
09-23-2017, 01:47 PM | #4 |
Re: Valve problem
Usual cause for a "sticky" valve is a weak or broken valve spring and/or a valve guide which swells enough when hot to grip the stem. A valve spring retainer that is not properly seated may also be a cause. In our rebuilds we use solid guides and straight stem valves, and never have a problem.
09-23-2017, 02:14 PM | #5 |
Re: Valve problem
"In our rebuilds we use solid guides and straight stem valves"
That's what I use in my rebuilds as well. Never a problem before this one. May have to pull the intake to see what is going on. Put the MMO in the gas and it's seems to be helping. Thanks Ron. Ed |
09-23-2017, 02:49 PM | #6 |
Re: Valve problem
For flatheads the fix was already mentioned. The Marvel Mystery Oil is a life saver on the old flatheads. Running at proper coolant temp is a very good idea as well so I can't add anything there. |
09-28-2017, 04:00 AM | #7 | |
Re: Valve problem
I have heard or read recently on the "magic" of bronze lined valve guides for a flathead. I don't recall seeing them sold anywhere, but if I remember correctly there was a company said they could do that to a set of stock solid guides. Thoughts? "Hard tellin' not knowin!" |
09-28-2017, 04:35 AM | #8 |
Re: Valve problem
Gary "GOSFAST" on this board has a company that does them. I have never used his guides, but have gotten a few other things from him and he really knows his stuff.
09-28-2017, 05:00 AM | #9 |
Re: Valve problem
Any machineshop can stick a bronze liner in a guide...the size is the same as for a SBC so not uncommon.
I ream mine in the lathe...install....trim...and hone to size in the Sunnen. Honing them is not needed if you arent to picky. |
