Old 09-21-2017, 05:56 AM   #1
smittykid
smittykid's Avatar
Question Thread size question
I have a Leakless water pump from Snyder's-the sealed unit no lube. I needed to remove the fan (alum 2 blade) to grind down the end of the housing for a little more pulley clearance. When I smacked the fan removal tool with a hammer, it wasn't on straight and boogered up the threads at the very end of the shaft. The castle nut will start, but I'm afraid to force it in fear of stripping the rest of the threads. What size die do I need to clean up those threads at the tip?
smittykid is offline   Reply With Quote
Old 09-21-2017, 06:13 AM   #2
noboD
Default Re: Thread size question
It sounds like you need a thread file instead of a die. Many times a die will not start on a boogered thread. The file is about $5.00 and will do several different pitches. I have fixed lots of threads with a thread file, google it. I don't have one of those pumps so I can't tell you the pitch.
noboD is offline   Reply With Quote
Old 09-21-2017, 07:07 AM   #3
slammin
slammin's Avatar
The tread file is a better solution. If you decide to use a die, make sure the die is an adjustable die. They are split and have a set screw to expand the size so you just clean the threads without changing the pitch diameter, making sure the die is square to the axis of the stud. Take the nut to the hardware store and find a bolt that it fits.
slammin is offline   Reply With Quote
Old 09-21-2017, 07:12 AM   #4
Rex_A_Lott
X2 on the thread file, it's a very handy tool to have. One thing you can do is to check it with a tap. Lay it alongside the shaft and when you find one that the threads nest perfectly , then you know what size die to use. Good luck.
Rex_A_Lott is offline   Reply With Quote
Old 09-21-2017, 08:03 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Even CHEAP tap & die sets have a THREAD GAUGE, to measure the thread PITCH!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-21-2017, 08:09 AM   #6
John Stone
John Stone's Avatar
Thread size is 7/16X20
John Stone is offline   Reply With Quote
Old 09-21-2017, 08:15 AM   #7
Afordman31
Afordman31's Avatar
Some Pictures
Afordman31 is offline   Reply With Quote
Old 09-21-2017, 08:21 AM   #8
Afordman31
Afordman31's Avatar
From John Stone's reply you will need a file that has a 20 thread size marked on it. The 20 thread size is a fine thread.
These files come in National Course, Fine , and Metric thread. Hope this helps!
Old 09-21-2017, 09:51 AM   #9
BILL WILLIAMSON
Threads were a MARVELOUS invention, just spend some time "pondering" THREADS & you'll be awake HALF the NIGHT!
Bill Easilymystified
Old 09-21-2017, 10:01 AM   #10
Terry, NJ
Terry, NJ's Avatar
As a former Tool And Diemaker, I have! In fact, I collect taps and dies in sizes I'll never use (1/4 x 24, 1/4 X 40, 3/8 X20, !/2 X 24, 9/32/ 24 etc) just because I like collecting them as I come across them. Weird, I know!
Terry
Terry, NJ is offline   Reply With Quote
Old 09-21-2017, 11:33 AM   #11
mike657894
mike657894's Avatar
I bought a motorcycle with a hammered end on a fly wheel thread. I used a needle file to clean out the end crank thread that was hammered. You only get to do one groove at a time but it was easy to make it look like it never happened.
these are the kind of needle files i use. I originally bought them to do some free form checkering on grip. but have found so many uses for them since. https://www.amazon.com/TEKTON-6655-N...s=needle+files
mike657894 is offline   Reply With Quote
Old 09-21-2017, 07:38 PM   #12
smittykid
smittykid's Avatar
Smile Re: Thread size question
Thanks guys! I bought a thread file from NAPA. After working with the thread file and a small flat file, I got it squared away. I must have boogered up the castle nut that came with the water pump as well as the shaft threads. After my filing on the shaft threads the original castle nut still didn't want to start. So I tried an old castle nut and it worked like a charm. Thanks again! Smitty
Old 09-21-2017, 07:44 PM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
Is there not a screw pitch gauge in your tap and die set if not maybe a friend has one.
Marvin/TN is offline   Reply With Quote
Old 09-21-2017, 08:32 PM   #14
smittykid
smittykid's Avatar
I found one-thanks!
