Old 06-19-2016, 02:59 PM   #1
fastroadster
Default Sarter Bendix
I'm having a problem removing the Bendix from my starter. Removed the screw, it comes part way off but seems to be stuck on shaft. Hit it with soft hammer...but will not come off. any ideas?? I'm running one of the "modern bendix" Thanks any help would be appreciated
fastroadster is offline   Reply With Quote
Old 06-19-2016, 03:34 PM   #2
john in illinois
john in illinois's Avatar
Default Re: Sarter Bendix
If I remember,the drive needs pushed toward starter to remove key and then will pull off. Anyway you need to remove key.
John
john in illinois is offline   Reply With Quote
Old 06-19-2016, 03:55 PM   #3
fastroadster
Thanks John will try that. Can't see the key, but must be on there........
