Old 05-03-2016, 12:41 PM   #1
HDowse
HDowse's Avatar
Default Pack front hubs with grease?
I'm working on the brakes on this survivor '40 Fordor. The front brake hoses were so bad they were solid, no visible passage for fluid. The steel lines are OK now that they've been blown out. New grease seals all around, front shoes good, rears covered in grease, to be replaced. Now to my question: the front hubs were filled with grease between the bearings and the bearings are fine. I cleaned out the old grease in the space between the inner and outer bearings. Should I pack that void with new grease? Thanks for the continuing help on this great old car.
HDowse is offline   Reply With Quote
Old 05-03-2016, 12:48 PM   #2
FLA48
FLA48's Avatar
Default Re: Pack front hubs with grease?
Yes. You do need to pack the front bearings with grease.
FLA48 is offline   Reply With Quote
Old 05-03-2016, 01:00 PM   #3
petehoovie
petehoovie's Avatar
" the front hubs were filled with grease between the bearings and the bearings are fine." - The grease worked, didn't it....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 05-03-2016, 01:13 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
No need to waste that much grease, as long as the bearings are PROPERLY packed with appropriate grease PLUS a smidge. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-03-2016, 01:29 PM   #5
Charlie Stephens
I want to be sure I understand what you are saying. The original post asked "Now to my question: the front hubs were filled with grease between the bearings and the bearings are fine. I cleaned out the old grease in the space between the inner and outer bearings. Should I pack that void with new grease?" Packing this area would take about a pint of grease. I have never done this and don't think it should be done. Are you trying to say that the hollow area in the center of the front hub between the inner and outer bearings should be filled with grease?
Charlie Stephens
Old 05-03-2016, 03:07 PM   #6
19Fordy
19Fordy's Avatar
Bottom line is that all that extra "filler" grease is not needed.
Just do as V8 said above.
Old 05-03-2016, 03:48 PM   #7
bbrocksr
This is the correct way!
Bill
bbrocksr is offline   Reply With Quote
Old 05-03-2016, 04:03 PM   #8
HDowse
HDowse's Avatar
Charlie, V8 and everyone, yes it's the void between the bearings (8 ounces' worth?) that was filled with grease. The young guy (just turned 81) helping me confirmed what you all have said. Pack them well plus a bit and they'll be OK. Thanks everyone!
Old 05-03-2016, 04:52 PM   #9
325w
In the late 50's at the Gulf station. Mr. Jernigan told me the correct way was to pack it full!
That however is not needed. Took several years and buying my own grease to change my mind.
325w is offline   Reply With Quote
Old 05-03-2016, 07:11 PM   #10
Ford46
Ford46's Avatar
Use a grease like Sta-Lube SL3131 Drum Brake grease. High temp grease will break down and make a mess of the bearings. JMHO. LouB.
Ford46 is offline   Reply With Quote
Old 05-03-2016, 09:54 PM   #11
alanwoodieman
definitely use SL3131 in rear bearings--remember they are not greased by the rear axle lube!! Sta-Lube is now part of CRC and it can be purchased at Napa stores
alanwoodieman is offline   Reply With Quote
Old 05-03-2016, 11:42 PM   #12
Drbrown
Drbrown's Avatar
Check out the Sta-lube prices on Amazon.com. I buy my Sta-Lube GL-4 85w-90 and 140w for my Tranny, OD and Banjo there and get free shipping.
Drbrown is offline   Reply With Quote
Old 05-04-2016, 04:50 AM   #13
HDowse
HDowse's Avatar
Yes, bought the SL3131 on Amazon. I used 85w-90 in the banjo and plan to use Mac's 600w in the tranny.
Old 05-04-2016, 06:09 AM   #14
Terry,OH
Terry,OH's Avatar
If you removed all traces of the old grease with a liquid cleaner, I suggest you do put some grease in the center of the hub and work it into all the crevices. This will prevent rust from forming.
Old 05-04-2016, 06:19 AM   #15
Frank Miller
Frank Miller's Avatar
I've never heard of this in automobile bearings but it's interesting reading.
http://www.machinerylubrication.com/...-overgreasing-
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-04-2016, 07:54 AM   #16
JSeery
JSeery's Avatar
Why? It is not intended for a V8 era transmission. Even Mac's tells you Ford Model T (1909 - 1927). It is for straight cut gears, the V8 transmission does not have straight cut gears. Why not use a proper gear lube in the transmission as called out by Ford?
