10-03-2015, 11:22 AM | #41 | |
Re: 1931 Pickup Journal
Yeah we could maybe meet up to even just talk model a stuff. Sent from my iPhone using Tapatalk
-Noah 1931 Model A Pickup My Model A : http://www.fordbarn.com/forum/showthread.php?t=173024 |
10-04-2015, 09:58 AM | #42 |
Love your truck. What is its name?
I'm with the others: do the safety work and drive it as it is. Grampa will be happy seeing it on the road again. |
10-04-2015, 10:47 AM | #43 |
Hi Noah,
Sounds like you got the carb figured out and she runs well. To take full advantage of the B carb at some point you will need to either bore out an A intake or get a B manifold. The B carb has a larger throat than an A carb. If I remember correctly it is the one with the vacuum port at the back of the manifold. There are two different ones and one will line up with the A choke rod and one won't. You have a great truck and I am glad you are keeping it in the family. Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-07-2015, 08:45 AM | #44 | |
Thanks. Truck doesn't have a name, we all just refer to it "The Model A." He and my mom, aunts, and uncles are all very pleased. I am going to have to find the pictures of them in the truck as kids. Sent from my iPhone using Tapatalk
10-07-2015, 01:46 PM | #45 | |
Bill W.
10-07-2015, 02:05 PM | #46 | |
I think the stats say just using the B carb it adds a HP or so while if you bore out your intake port, you can get additional HP's. Good luck with your pickup. BTW did you change the oil before you started running it around? May want to do that because the oil may contain a lot of stuff that doesn't do your engine much good.
Fred Kroon 1929 Std Coupe 1929 Huckster |
10-07-2015, 06:09 PM | #47 | |
I think you're right. A shop had some dyno numbers with the various combinations, but the B carb didn't look like it really have any gains. I changed the oil before running it. The oil pan and rear main seals are leaking pretty badly so I will drop the pan and really clean it out and change the oil again this winter. Sent from my iPhone using Tapatalk
10-07-2015, 09:37 PM | #48 |
I remember Daddy turning the engine off and coasting every chance he had to save gas during the war.
Sewall |
10-11-2015, 05:39 PM | #49 |
I figured out that the bulbs are blown and that's why I lost the headlights during the last drive.
10-12-2015, 06:11 AM | #50 |
You either reached the advertised 1000 hour use, or more likely had a voltage spike from a bad connection, if you use an unregulated generator. If you use an alternator, it's recommended to make sure the alternator is already kinked in and charging before you turn on the lights.
10-12-2015, 07:19 AM | #51 | |
I am not sure if I have an unregulated generator or not. Should I replace the bulbs and see how it goes or is there a good way to test the connections to see if there is a bad connection? They worked fine for a while and then blew when I was taking it for its first real test drive with the lights on. Sounds like it could be a spike because of that and what you said. Thanks. Sent from my iPhone using Tapatalk
10-12-2015, 07:22 AM | #52 |
Another topic, I have been trying to flush out the radiator and it comes out looking like this:
I have distilled vinegar in there now and already did that flush once. I got it nice and hot yesterday with the vinegar in there and will maybe get another shot at driving today. Would you recommended continuing to flush or just pulling the radiator to take it somewhere to get cleaned? I haven't flow tested it yet. Sent from my iPhone using Tapatalk
06-11-2016, 12:46 PM | #53 |
I have been doing some work on the truck recently. I replaced the tires that had a date code from 1943 with some fresh Goodyears:
06-11-2016, 12:50 PM | #54 |
I replaced the spark plugs with some hotter ones. I went with Champion W16Y I bought on
After taking it for a spin, I still had bad overheating problems. I pulled the radiator to swap the spare I have that is in better shape. I am going to take it to a radiator shop to make sure its completely clean before installing it. There was a thick brown sludge that came out of the one I removed. "New" is on the right.
06-11-2016, 01:14 PM | #55 |
Flush the block before you reinstall a radiator. the vinegar loosened up alot of stuff you never want in the radiator. If you are going to run straight water add soluble oil (napa carries it) to lube the waterpump, and maybe napa cool to retard rust.
There is another school of thought to use antifreeze. Bob |
06-11-2016, 02:53 PM | #56 | |
What's the best way to flush the block? I have to imagine it's as bad in there as it was in the radiator. I was going to run distilled water with Redline Water Wetter. Sent from my iPhone using Tapatalk
06-11-2016, 11:37 PM | #57 |
I rigged up some pvc fittings to clamp to the outlet so I could run water from a hose into the block and also have an air line coupler so i could push the water out the block inlet. I used a long piece of radiator hose on the inlet(drivers side of the block) to run it into a pan under the car. I then would strain the captured discharge and filter it thru a funnel with an old t shirt to see what was coming out.
I also reversed the setup to try and flush out the head and got more stuff that way. |
06-12-2016, 12:32 AM | #58 | |
http://www.fordbarn.com/forum/showth...ator+sump+pump |
06-12-2016, 04:03 AM | #59 |
Rube Goldberg back flushing contraption. Interesting to note difference in results after adding air to back flushing procedure. I had flushed this engine for several hours just using water and water looked fairly clean. Third photo shows results after first blow with air pressure.
I Love Anything That Turns Money Into Noise |
06-12-2016, 07:00 AM | #60 |
What Bill shows in the pan is also what my sump pump drove out of the block and radiator times 3. That's why I would recommend a filter in the top hose, at least for several miles until you are sure you have trapped the junk before it plugs the tubes.
