Old 12-26-2014, 01:48 PM   #1
Ed Solari
Default epoxy weld rumble hinge
My 33/34 rumble hinge is repo and mounting tab need enlargement and re-drill. Beside welding (issues with iron weld being hard to do ) is there a build up epoxy (like JB weld) what could add to tab size and really stick to the cast iron???? Some suggested fiber glass but I think the strength is not there. Anyone tried to do epoxy?
Would love OEM but can not find a set... PM or email if you can help
Thanks
Ed Solari
Ed Solari is offline   Reply With Quote
Old 12-26-2014, 03:10 PM   #2
34pickup
34pickup's Avatar
Default Re: epoxy weld rumble hinge
My opinion is not worth a lot perhaps, but I don't think any kind of plastic repair like epoxy or fiberglass would hold up to the operation of a hinge. I think you would end up redoing it sooner than you would like. Repo everything is crap. You have to buy it knowing you will probably have to modify it to work properly. A welding shop could probably do that for you if you don't think its within your expertise.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 12-26-2014, 03:36 PM   #3
FlatheadTed
FlatheadTed's Avatar
Ed I think you could brass it using bronze rod just pre heat it ,fill the hole then add some bronze on the end of the bracket to lengthen it then re drill the hole slightly over to line up . This way there is no join in it but the load will be on the casting still .I may have to do the same as I have a re poped bracket to .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-26-2014, 03:46 PM   #4
Karl Wolf
Karl Wolf's Avatar
The holes in my 1930 Model A Roadster repop deck lid were not even close to what the original hinges called for. I managed to just barely start all the screws. I tightened them gradually and things seemed to work out OK. Not all screws were centered in their respective holes. I wasn't real happy, but the compromise suited the situation.
I agree with the bronze rod idea, also.
Karl
Karl Wolf is offline   Reply With Quote
Old 12-26-2014, 04:20 PM   #5
FlatheadTed
I just checked mine the holes are spot on ,NOS ? maybe ,part # 40-718571 -B or 713571 -B .If any one wants a casting of mine I would look at it .Ted
Old 12-26-2014, 10:02 PM   #6
john worden
john worden's Avatar
This.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 12-26-2014, 11:33 PM   #7
DavidG
DavidG's Avatar
Steel originals show up with some regularity on eBay.
