Old 01-09-2021, 07:07 PM   #1
41panelmark
41panelmark's Avatar
Default Crab distributor or ???
I am thinking of updating my 59a to a crab distributor instead of the helmet. I have converted the car to 12 volts, neg. ground and would like have a reliable coil/distributor. The old helmet distributors are pretty good if you are running 6 volts but not sure so much about going to 12 with them.
I have been working on one that has a traditional coil converted to 12 volt but not having much luck with it.
I would like to hear people who have done this and if it the results were good on going to the crab and using 12 volt components from members here. I am sure this has been done more than once.
I understand that there is an adaptor plate that can be used to make this up without having to swap the front cover.
What about going to a modern crab type?
Thanks in advance.
41panelmark is offline   Reply With Quote
Old 01-09-2021, 07:27 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Crab distributor or ???
Your helmet can be set up just like a crab (contact Mike @ thirdgen) the have skip rewind a helmet coil for you set up for 12v whatever polarity you choose & you will have a winner.
KiWinUS is online now   Reply With Quote
Old 01-09-2021, 10:18 PM   #3
JSeery
JSeery's Avatar
The distributor doesn't care about the voltage or polarity you are using. The coil is a different story, both matter.
Old 01-09-2021, 11:50 PM   #4
Brian
Brian's Avatar
I feel the earlier helmet distributors are better on 12 jolts than the crabs. The crab caps seem to develop carbon tracking leading to mis-firing etc.
Old 01-10-2021, 07:36 AM   #5
Ol' Ron
Ol' Ron's Avatar
Didn't the 59 come with a crab dist??It;s a very good dist in proper working condition on either 6 or 12 v.
Gramps
Old 01-10-2021, 06:26 PM   #6
41panelmark
Thanks for the replies.
Thanks guys, I am burning up points very quickly. I was told to use a 1.5 ohm resistor which just did not bring the voltage down close enough at the coil. I tried a 2 and a 2.8 but still no go. I did check the resistance of the coils and they appear to be running around .48. Shouldn't they be higher like .8 or 1?
I am guessing that even at .48 maybe I can run 2, 3 ohm resistors and solve this problem, what do you think?
Old 01-10-2021, 06:42 PM   #7
tubman
tubman's Avatar
Points burning indicate a condenser that is way out of spec.
Old 01-10-2021, 07:19 PM   #8
41panelmark
I should clarify that it is only the primary set of points that is being affected. The condenser is showing about .35 mf.
Old 01-10-2021, 08:03 PM   #9
tubman
tubman's Avatar
Have you tested it when it's hot? Or over a period of time? The ability of the condenser to do it's job can vary greatly with both of these conditions.
Old 01-10-2021, 09:19 PM   #10
41panelmark
The resistor is supposed to be a 3.0 but is showing around 2.8.
Not enough to get to 3.5 or 4 volts needed at the coil which shows .48 ohm resistance.
Do I in fact need 2, 3 ohm resistors here?
(reminder I have converted this to 12v, neg ground).
Old 01-10-2021, 09:20 PM   #11
41panelmark
No but that will be next.
Old 01-11-2021, 12:02 AM   #12
JSeery
JSeery's Avatar
Are you attempting to run an original Ford coil on 12v? The 1.5 ohm ballast resistor is what is normally coupled with a 1.5 ohm coil. You need something in the 3.0 to 4.0 ohms total in the circuit. A 0.48 ohm coil would need a ballast resistor somewhere in the 2.5 to 3.0 range. Not sure you are trying to run this type of setup, I would get a proper coil.
Old 01-11-2021, 12:13 AM   #13
35fordtn
35fordtn's Avatar
I helmet with 11A internals properly setup on a sun machine will be better than a crab distributor in my opinion. As for coils, your primary total resistance needs to be around 3.0-3.5 ohms. Bosch makes a good 3.3 ohm epoxy filled coil, and standard makes a 3.0 ohm oil filled. As mentioned the condenser needs to be tested not just for a reading but also to be sure it holds a charge and doesn’t leak down too fast. Too much dwell can believe it or not Cause points of lower quality to prematurely burn as well. What is your dwell set to on your distributor?
Old 01-11-2021, 01:57 PM   #14
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Just to add to the discussion on a helmet only one set of point will burn up , they use a make set ( makes the circuit) and a break set (opens the circuit ) ... The only set that arcs is the break set.......Get a 1.5 ohm coil amd use a 1.5 ohm ballast or a 3.0 Ohm bosch coil # 00012
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-11-2021, 02:17 PM   #15
Tim Ayers
Can someone tell me where to find the part number on helmet to see which guts it has?
Old 01-11-2021, 02:25 PM   #16
35fordtn
35fordtn's Avatar
The tang that mates to the camshaft has a stamp that will say either 68, 11A or 40B
Old 01-11-2021, 03:17 PM   #17
Tim Ayers
Thank you.
