Old 09-17-2020, 04:19 PM   #1
fourfords
fourfords's Avatar
Default Gas not getting to Carburetor
I couldn't drive my '37 for several months this year. During this time it seems the fuel line has become clogged. Question: Before I dismantle the fuel line, will blowing it out with a compressor likely solve the problem? or solvent poured down line?
File Type: jpg 1937 Ford, 1st day home 4-12-2007 001.jpg (76.1 KB, 7 views)
fourfords is offline   Reply With Quote
Old 09-17-2020, 04:51 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Gas not getting to Carburetor
Blowing back to the tank may clear it, but don't blow through the pump, as that may damage the diaphram. You may also remove the flex hose for inspection, as it may be swollen closed or collapsed from modern fuel. Removal of the pump's top may reveal the suspected sediment, but hold off on that unless you have a good replacement gasket.
Alan
Old 09-17-2020, 05:01 PM   #3
fourfords
fourfords's Avatar
Thanks for the tip!! Don't want to screw this up!
Old 09-17-2020, 05:40 PM   #4
woodiewagon46
I had the same situation and it was the flex line. The new Ethanol fuel attacked the rubber. If you are going to try to clear it with your compressor, do not blow it back to the tank, all you are doing is pushing the crud back to the tank. The Ethanol might have attacked the diaphragm in the pump also.
woodiewagon46 is offline   Reply With Quote
Old 09-17-2020, 05:49 PM   #5
corvette8n
corvette8n's Avatar
While fixing the exhaust on my ‘41 I discovered another fuel filter in the frame rail mounted before an in-line 6 volt fuel pump. I knew the previous owner said he mounted an electric pump that ran off an intermittent switch, but I didn’t realize there was a filter there also. So my car has two fuel filters and a sediment bowl. Something to check.
