Old 09-30-2016, 11:05 AM   #1
fastroadster
Default Loss of power
A friend of mine is having problems with his 30 CCPU. After truck warms up it has a loss of power.... any ideas?
fastroadster is offline   Reply With Quote
Old 09-30-2016, 11:20 AM   #2
Bob C
Default Re: Loss of power
Bad condenser?? Check the condition of the spark from the coil secondary wire
when this happens.
Bob
Old 09-30-2016, 11:40 AM   #3
SeaSlugs
SeaSlugs's Avatar
Yea need some more info:
Does it stumble or die?
Overheats?
Missing fluids?
Does it idling?
Does it driving steady?
Does it up hill?
What has he tried?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-30-2016, 11:52 AM   #4
heneste
heneste's Avatar
How old is his coil? If the coil is on it's way out it could be heating up and not providing adequate spark once the vehicle is at operating temp.
He should also run a compression test to check if his head gasket is still fine. he may be getting blowby with a loss of compression in one or more of the cylinders.
heneste is offline   Reply With Quote
Old 09-30-2016, 12:02 PM   #5
Terry, NJ
Terry, NJ's Avatar
Is his valve valve lash too close? He should run a compression check when it hot.
Terry
Terry, NJ is online now   Reply With Quote
Old 09-30-2016, 03:03 PM   #6
Mitch//pa
Originally Posted by tbirdtbird View Post
you need spark, fuel, and compression to make it run.......
And air
Old 09-30-2016, 07:52 PM   #7
Terry, NJ
Terry, NJ's Avatar
And Timing! Don't forget everything must be in time.
Terry
Originally Posted by Mitch//pa View Post
And air
Old 10-01-2016, 12:26 AM   #8
700rpm
700rpm's Avatar
And money.
Ray Horton, Portland, OR
