Old 04-06-2016, 09:06 PM   #1
postaltruck31
postaltruck31's Avatar
Default How do you remove window garnish on a 27 Coupe door?
On a 1927 Coupe, how do you remove the U shaped garnish that goes around the window on the doors?
Also, does anyone have that garnish for the driver's door?
[email protected]
postaltruck31 is offline   Reply With Quote
Old 04-07-2016, 07:08 PM   #2
dlmyerspls
Default Re: How do you remove window garnish on a 27 Coupe door?
I think they slide straight up.
dlmyerspls is offline   Reply With Quote
Old 04-07-2016, 09:52 PM   #3
Jeff P. / MN
Jeff P. / MN's Avatar
On the 1926-27 Improved Fords the doors are the same for Coupes and Tudor sedans.
Jeff P./MN
1913 Model T Runabout
1926 Model T Sport Touring
1948 Chrysler New Yorker
Jeff P. / MN is offline   Reply With Quote
Old 04-09-2016, 05:42 PM   #4
t42
Remove the screws and slide straight up. Mine has a rubber cushion on the top rail that needs to be removed first, the sides have a bracket that the garnish slide over. These brackets are very hard to remove with nuts that are not accessible. Good luck, they tend to brake when sliding out.
t42 is offline   Reply With Quote
