09-04-2015, 11:38 AM | #1 |
60hp part id
09-05-2015, 09:35 PM | #2 |
Re: 60hp part id
Whoa, do I get a medal of some kind for stumping everyone on this part?
I still don't know what it is. |
09-05-2015, 10:17 PM | #3 |
Re: 60hp part id
If it didn't come from an old Ford it might stump folks on this forum. I'm not familiar with any distinct differences between the engine or chassis components of the V8-60 cars and the other Fords other than the round tube front axle. If there is a knuckle used in that suspension for a panhard rod or a stabilizer then someone ought to remember on here but I sure can't tell you for sure. It does look suspension related though.
09-05-2015, 10:40 PM | #4 |
Re: 60hp part id
Top view showing all the numbers might help.
09-06-2015, 08:00 AM | #5 |
Re: 60hp part id
The number is C-374.the re The only thing I could find, said something about a cam chain adjuster, but it didn't say if it was even Ford related.
This part was in a box with 3 sets of 60hp pistons, lots of rings, main and rod bearings, all new. It also looks like a suspension part to me. Thanks, Lee |
09-06-2015, 08:13 AM | #6 | |
Re: 60hp part id
I have several 60hp engines and know the vehicles they were used in pretty well, and I have never seen a part like that on any of them. Make it a wall hanger for now, and maybe you will figure it out later.
09-06-2015, 04:23 PM | #7 |
Re: 60hp part id
Same as above.
09-06-2015, 04:29 PM | #8 |
Re: 60hp part id
Looks like part of the throttle linkage from a 2/8/9N Ford tractor. Bolts to the head and a rod goes in it.
09-06-2015, 05:00 PM | #9 |
Re: 60hp part id
Oh Jim, now I gotta buy a tractor? I think it will be a wall hanger as suggested.
09-06-2015, 05:27 PM | #10 |
Re: 60hp part id
A size scale would be helpful too...could be a wing attachment bracket for a 747 but I'd guess it's smaller than that
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
09-06-2015, 07:57 PM | #11 |
Re: 60hp part id
I thought about that also. It is only (roughly) about 3" center to center on the two matching holes. The opposing hole is about 1 1/2" from the hole above it.
Lee |
09-06-2015, 08:11 PM | #12 |
Re: 60hp part id
My first impression was that it was a suspension part. No idea about anything else.
09-07-2015, 03:59 PM | #13 |
Re: 60hp part id
Checked my 2N and 8N today, its a 2N which is the first series of the n Ford tractors starting in 39.
The 9n and 8n use a different throttle setup. |
09-07-2015, 04:09 PM | #14 |
Re: 60hp part id
9n was first in series-1939. 2n-1942. 8n-1948
I dig coal, which provides motivation for EVs. |
09-07-2015, 05:18 PM | #15 |
Re: 60hp part id
2N tractors (1942) were originally sold as war time products. The had magnetos with no electrics and steel wheels. Many were converted to 9N configuration after the war. All of them were similar with 4-cylinder flathead 120 CID engines and the gear drive governor set up. I don't recall a part like that on them but I do know that some were set up to run on kerosene and other oddities over their production span.
09-08-2015, 07:38 AM | #16 |
Re: 60hp part id
Then it is a 9n, it has the alum steering gear box and dash. Rod that goes in this bracket starts from a hole in the dash and runs forward with linkage to the gov.
09-08-2015, 02:05 PM | #17 |
Re: 60hp part id
Thanks guys. Guess I can put this part to rest now. If someone needs it, just let me know, and I will send it to you. I have no need for it.
Lee |
