Old 07-08-2023, 09:15 AM   #1
harleycontracter
Default Fender question
The front fenders on the front fenders I bought they have a slight raised crease in the center of the fenders. They fit perfectly Obviously factory . I've never seen that.
I thought all fenders and splash pans etc.. were the same 30/31 ????
harleycontracter is offline   Reply With Quote
Old 07-08-2023, 09:36 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Fender question
I am not following you when you say "...the front fenders on the front fenders", ...as to indicate there is one fender on top of another. There is a distinct difference between the 1930 fender with the two-piece body apron vs. the late 1930-31 front fender with the one-piece apron. Also differences between the fenders with the fastener counter sunk support, and also the Sedan fender often referred to an the 'eyebrow' fender. Maybe you could post some pictures so we can better explain what you are seeing??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-08-2023, 09:54 AM   #3
jwmckenzie
Are you talking about eyebrow fenders? They had a detail on the front edge of the fender that is not on most fenders.
A pic would be helpful.
oops, should have read the rest of Brent's post....
jwmckenzie is offline   Reply With Quote
Old 07-08-2023, 09:55 AM   #4
harleycontracter
I meant on the center of the front fender. They are not at my house they're ay my shop. I'll take a pic later. Not sure the raised crease will be visible in a pic .
Old 07-08-2023, 10:12 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
"Eyebrow" Fender
Old 07-08-2023, 10:20 AM   #6
harleycontracter
No Not eyebrow. This is a raised seam that goes down the center of the fender front to back Very slight raised area . I thought they were damaged until I noticed both sides were identical
Old 07-08-2023, 10:21 AM   #7
harleycontracter
I'll post pics Monday
Old 07-08-2023, 11:51 AM   #8
harleycontracter
A friend checked his fenders . One has the same I have and another one is smooth. Question resloved ...........
Old 07-08-2023, 02:55 PM   #9
TerryO
TerryO's Avatar
If you are referring to how close the crease comes to the front edge of the fender I have some of both. You have to be really observant to notice it. One of my cars has one of each and I had never noticed but the others I think are matched...
TOB
TerryO is offline   Reply With Quote
