Old 07-14-2022, 09:34 PM   #1
Pete
Pete's Avatar
Default Oil pumps
Anybody see the TV show on dyno testing oil pumps last night?
Pretty much laid to rest the old wives tale about high volume pumps sapping extra power, washing out bearings, blowing seals etc etc.
The pumps tested were a stock one, a high pressure Melling, a high volume Melling and an aftermarket Milodon billet one.
All pumps were tested under the same conditions on a wet sump Mopar engine.
Pete is online now   Reply With Quote
Old 07-14-2022, 09:52 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Oil pumps
Hey Pete - point me to the link/show, would love to see it.
Old 07-14-2022, 10:01 PM   #3
Pete
Pete's Avatar
I have no idea what channel it was on. I was just surfing and came on to it.
They usually run those kind of shows several times a year.
Old 07-14-2022, 11:29 PM   #4
tubman
tubman's Avatar
I'll bet it was "Engine Masters" on the Motor Trend channel.
They do all kinds of comparative dyno runs such as this.
tubman is online now   Reply With Quote
Old 07-14-2022, 11:33 PM   #5
Tinker
Tinker's Avatar
I'm not saying tv shows do things on sponsor money and make content based on that.
Beats putting heavy oil in your car to increase numbers.
Your basic flathead will run fine with just 10lbs hot. But flatheads are a low pressure oil system. Just off a gravity system till the B motor. I don't want to rewrite history here.
Old 07-14-2022, 11:41 PM   #6
Tinker
Tinker's Avatar
I worked in the info world for a decade in my early days. The thought was always if you see something advertised for a long period. It means it works. Media buys are expensive and they only buy more media if the items sales are high and returns are low. ...
Old 07-15-2022, 12:17 AM   #7
cas3
I've not seen the video, but based on common sense and experience with all kinds of contraptions from shallow well pumps to home made hydraulic wood splitters you can not convince me that high volume or high pressure pumps do not take more power to run. Its basic physics, and not required for our old low RPM motors. Going racing? Thats another story. Pete, and Ronnie, and others that race may correct me, But me being only a racing fan have always read the high RPM race motors run a slightly looser clearance on the crank and rod bearings than we would want on a cruiser motor so the high volume / pressure pump would be the choice for that application...but not for us mere mortals.
Old 07-15-2022, 12:44 AM   #8
Tinker
Tinker's Avatar
Ya but cas, if you aren't cruising a blower flathead or a flathead with more then 1 carburetor you are not a flathead guy or know anything about it.
Old 07-15-2022, 01:06 AM   #9
cas3
Tinker, you are correct, I know nothing about blowers and multi carbs. Had some hotrod chevys in the 80's, and even then I learned that big horsepower costs big money. Broken parts, big insurance, police tickets, all done with that. I drive my cars a lot. Under the new Marxist regime I may have to get out of retirement and get a job so I can continue my daily sunset cruise in the country , much less buy blowers and piles of carburetors.
Old 07-15-2022, 01:46 AM   #10
Tinker
Tinker's Avatar
Well I'm not going to touch that last part. The world is hurting, but we can cruise a flathead sometimes. It's a global issue. Glad to not live in sri lanka and other areas. (we are oing to see a lot of fallout around) Hey one good thing here is the dollar is stronger then ever. Euro is 1:1 now and the rupee is 80:1.
Not to make lite... but the job market is strong, so
Old 07-15-2022, 07:11 AM   #11
mfirth
As to "new" Mellings oil pumps, my experience was that the new one made less oil pressuree than the old stock Ford did on a fresh rebuilt 8BA.
mfirth is offline   Reply With Quote
Old 07-15-2022, 08:27 AM   #12
Ziggster
After reading about so many issues with the Mellings' pumps, I decided to rebuild mine. Maybe I was lucky, but between two old pumps, I managed to make one. The old stuff for the most part is built much better than most of today's stuff. The fact that many of these items are approaching 75-100 years old speaks for itself.
Ziggster is offline   Reply With Quote
Old 07-15-2022, 02:24 PM   #13
Pete
Pete's Avatar
You guys forget, all the pumps tested were regulated (bypassed) to the same (or very close) pressure out. You can not have a valid test otherwise.
Hp in will be the same with a large pump for same pressure out MINUS frictional losses.
Frictional losses amount to both mechanical and flow.
Old 07-16-2022, 09:58 AM   #14
39fordtruck
Can Melling pumps be a problem? How would you check a used M19 before using?
39fordtruck is offline   Reply With Quote
Old 07-16-2022, 11:05 AM   #15
flatjack9
flatjack9's Avatar
I built a test rig.
Old 07-16-2022, 01:04 PM   #16
tomcarman
tomcarman's Avatar
I stumbled upon this while channel surfing and caught the tail end so I'm not postive it's the show Pete is referring to, but it was "Engine Masters" season 3, episode 3. It was interesting.
tomcarman is offline   Reply With Quote
Old 07-16-2022, 07:29 PM   #17
Ronnieroadster
Ronnieroadster's Avatar
During a test run of one of our race cars we experienced a failure of an oil pumps pressure regulator the pump is a Melling M-15. Data showed the pressure spiked to 225 PSI pump has not been removed yet to determine what caused the failure.
On my pump dyno testing the M-21, M-15 and M-19 I will say is a messy affair.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
