Old 01-14-2021, 03:26 PM   #1
Gufshoz
Gufshoz's Avatar
Thumbs up Thermostat update.
In a previous post I told about not being able to get up to operating temperature since I installed engine pans. I drove around for a while with a cardboard shield over my radiator, but still couldn't get above 110 degrees. I did check my temperature gauge in hot water against a thermometer and the gauge was functioning well.
Today I installed a Vintage thermostat assembly and took a test drive. The thermostat in the kit was set for 160 degrees and that's exactly where the engine temperature gauge stayed. It was a pretty simple installation other than having to remove the hood so I could tilt the radiator in order to get a new radiator hose in place.
I'm very happy and if I should have any issues down the road, I'll be certain to post those as well.
Gufshoz is offline   Reply With Quote
Old 01-14-2021, 03:43 PM   #2
CarlG
CarlG's Avatar
Default Re: Thermostat update.
You don't have to tip the radiator to get a hose on. Just remove the top of the T-stat housing (4 bolts). Easy-Peasy.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-14-2021, 06:57 PM   #3
shew01
shew01's Avatar
I installed one about 6 months ago. It works like a champ, and I am very pleased with mine.
Old 01-14-2021, 08:41 PM   #4
Chris Haynes
Chris Haynes's Avatar
I just wish they made one that would fit a Riley head.
1921 Runabout
1930 Tudor
Early 1930 AA
Chris Haynes is online now   Reply With Quote
Old 01-15-2021, 07:59 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
Put a thermostat in the upper radiator hose instead of the head.
Bob Bidonde
Old 01-15-2021, 01:44 PM   #6
Chris Haynes
That has no provision to mount a temperature sending unit as the Vintage unit does. It just looks clean and sanitary.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-15-2021, 02:29 PM   #7
Gufshoz
Gufshoz's Avatar
Carl,
I didn't read the installation instructions closely enough as well as rushing the job. I made the mistake of putting on the unit before I checked the clearance for the temp sender (as instructed) and I didn't want to remove and clean the new RTV sealant.
The upper hose had to be replaced because it had the mid-hose mount for the temperature sending probe. At least it went on the first time. Normally it takes me three attempts before I get it right.
Old 01-19-2021, 07:34 AM   #8
Flyboy1st
I put a Brattons 160 degree thermostat in my 1929 coupe, in the upper hose at the top. It works good, I used to see a lot of light colored oil from moisture in the oil filter when I changed oil. Since I have installed the thermostat the engine warms up quick and no moisture in the oil, I do a lot of short trips and the engine never heated up until I installed it. Engines no matter what kind must get to a certain temp to operate at peak performance and rid itself from condensation.
Flyboy1st is offline   Reply With Quote
Old 01-19-2021, 11:01 AM   #9
katy
katy's Avatar
I'll second that!
Old 01-20-2021, 12:25 AM   #10
barry022
The advantage of operating internal combustion engines at an elevated temperature has been proven to reduce engine wear, but engine failure that may have been precipitated by the installation of a thermostat in a Model A engine is cause for concern as noted in this article.
http://www.santaanitaas.org/wp-conte...tat-Theory.pdf
barry022 is offline   Reply With Quote
Old 01-20-2021, 01:47 AM   #11
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
We all knew a thermostat would help you get it up.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 01-20-2021, 04:58 AM   #12
DkFordor
Interesting article! If steam is indeed formed in the circuit it can block waterflow, further reducing cooling. This effect is present and a real danger on some motorcycle engines.
But wouldn't a (number of) bypass hole(s) be able to ensure a persistent minimum waterflow?
\Dan
DkFordor is offline   Reply With Quote
Old 01-20-2021, 09:44 AM   #13
Dave in MN
Dave in MN's Avatar
\Dan
DkFordor, ....."minimum waterflow"
For years, I have enlarged the two holes to 3/16" in the thermostat shown in a previous post by Bob Bidonde. I then add two additional 3/16" holes. The thermostat still functions but it takes longer for it to do so. I have not had any problem with #4 cylinder when using the modified thermostats.
My original reason for adding the holes was I wanted the initial warm-up to be more gradual so all areas of the engine come to the higher temp more uniformly. I was concerned with the two back cylinders and pistons overheating after reading an article many years ago about the water flow to the rear of the engine being marginal. I also worked on many customers engines that showed some scoring on the pistons adjoining the "siamese" area between cylinders 3 & 4.
I cannot say for sure if the modified thermostat is the reason I have not experienced an issue with the rear two cylinders as I also make it a practice of honing a bit more clearance (couple ten thousandths) on the rear two cylinders when rebuilding engines. I know...it's not a normal practice to provide a bit more clearance on the rear two cylinders but it works for me. I have not noticed anything negative to using both practices to keep the engines running. Cylinder compression, cylinder leak down tests and carbon buildup in the combustion chamber all appear to be equal between the cylinders.
Good Day!
Dave in MN is offline   Reply With Quote
Old 01-20-2021, 11:33 AM   #14
WHN
I have mentioned this many times over the years, sorry for doing it again.
For all of us old enough to remember, back in the day, thermostats were removed from cars in the spring and put back in in the fall. There was a reason car owners did this. Cars over heating or running hot in the summer heat.
Cars today have water pumps installed were the water comes into the engine, not at the point water leaves. Also, the syphon effect was used not only for the Model T, without a water pump, but also with the help of a water pump on the Model A.
Technology has come along way since 1928.
Enjoy.
