11-10-2021, 02:12 PM | #1 |
Radiator Identification
Can anyone tell me which year vehicles these brass radiators go to. The smaller upper hose openings ( black radiator ) are 1.25” diameter. The brass one leaks. The black painted brass one is OK. Does anyone have a general value as is, considering mounting brackets are cut or partially missing?
The black one has this designation to the upper right side ( by the hose connection ) IBA-D under that G I The brass one has a designation 21A then under that G Thank You Joe Last edited by Bazooka Joe; 11-10-2021 at 06:08 PM. |
11-10-2021, 02:16 PM | #2 |
Re: Radiator Identification
Don't look like Ford's to me!!! at least not through 1941 unless they are Truck rads of which I have NO experience with
11-10-2021, 02:23 PM | #3 | |
11-10-2021, 02:47 PM | #4 |
11-10-2021, 03:33 PM | #5 |
Winner, winner, chicken dinner...
11-10-2021, 03:36 PM | #6 | |
11-10-2021, 06:04 PM | #7 |
"1BA" is 1951 Ford, which coincides with the 1.25 inch top outlets.
11-10-2021, 06:11 PM | #8 |
11-10-2021, 06:15 PM | #9 |
I imagine they are virtually the same, '49-'51. There may have been some minor modification made for 1951, as a few things changed; rotator valves and the Ford-a-Matic transmission to name a couple, but since the Ford-a-Matic was air-cooled, I can't imagine what it is
11-10-2021, 06:30 PM | #10 | |
11-10-2021, 06:39 PM | #11 | |
As "Kube" noted above, "21A-" denotes 1942 Ford passenger car as the main, intended application. The inverted "U" section at the bottom coincides with the area that allows clearance for the use of a hand crank. I know that this same feature was also used on '37 radiators. DD |
11-10-2021, 06:43 PM | #12 | |
My 39 Deluxe has the hole in center grille chrome trim and they made radiators with a gap for a hand crank also as another year. https://cdn.dealeraccelerate.com/sun...939-ford-coupe Not my car Last edited by Bazooka Joe; 11-10-2021 at 06:50 PM. |
11-10-2021, 07:37 PM | #13 | |
Here's a '38 radiator....SAME feature, and I'd bet a '39 STANDARD radiator is probably the same. As you probably know, the '39 Standard and DeLuxe radiators are completely different. DD . |
11-10-2021, 08:24 PM | #14 | |
I have tried to sell numerous radiators that were at least as nice as yours and more popular (39 deluxe / 40 all). When there were no bids at $49.95, they went to the scrap yard. Brought 18 of them in. Got a bit better than $1000.
11-10-2021, 08:31 PM | #15 | |
