Old 12-01-2021, 08:58 AM   #1
Ramblin Reck
Ramblin Reck's Avatar
Question Just Out of Curiosity
Just Out of Curiosity...........
Has anyone installed an electric fan in front of the radiator on a '39 Ford Deluxe; (85 or 100HP Flathead)?
Waste of time and money or does it help, especially in stop and go traffic?
THANKS TO ALL FOR YOUR COMMENTS! RAMBLIN RECK DEC 2, 9:34EST
Last edited by Ramblin Reck; 12-02-2021 at 09:34 AM. Reason: TO THANK ALL WHO COMMENTED
Ramblin Reck is offline   Reply With Quote
Old 12-01-2021, 09:08 AM   #2
RKS.PA
RKS.PA's Avatar
Default Re: Just Out of Curiosity
RR, yes, I did it, with a switch on the dash, it helped a lot in parades, etc. Well worth the effort. However, when I rebuilt my engine, I should have spent more time cleaning out the block...but live and learn!!
RKS.PA is offline   Reply With Quote
Old 12-01-2021, 06:28 PM   #3
flathead4rd
flathead4rd's Avatar
I think puller fans are more efficient but it depends how much room you have to work with.
flathead4rd is offline   Reply With Quote
Old 12-01-2021, 06:38 PM   #4
RKS.PA
RKS.PA's Avatar
I agree, but in my '39 Deluxe, I used the stock fan as a full time puller, and the front mounted pusher as needed. As you said, it depends on how much room you have.
Old 12-02-2021, 08:18 AM   #5
aussie merc
aussie merc's Avatar
try to make sure that the fans are offset i believe that the 39 fan sits below the centre of the rad so mount the electric as high as possible
aussie merc is offline   Reply With Quote
Old 12-02-2021, 09:14 AM   #6
38bill
38bill's Avatar
I run a mechanical fan and a electric pusher. My flathead runs cool so I rarely use the pusher but it does work well when needed.
38bill is offline   Reply With Quote
