09-13-2023, 08:22 PM | #1 |
34 coupe seat slider latch
I am finally putting the correct seat in my 34 3w, and I can not find the latch/lock thingy that mounts to the floor. I had one...I know what it looks like...but its missing in my mess. I have the saw toothed thing for the seat frame, but not the latch for the floor and if one of you guys has the time and the part, please post a pic and some basic dimensions so I can make one. Its under the seat, no one will know except us! Thanks !
09-14-2023, 09:33 PM | #2 |
Re: 34 coupe seat slider latch
This part is visible by just lifting out the bottom seat cushion. I believe there are different latch mechanisms between the 33 and 34, mine is possibly the 33 style as its a body out of Canada, none the less, its the "saw tooth" style I have.
Its a L shaped bracket, bolts to the floor, with a key hole shaped hole to allow you to move the seat to a different saw tooth notch. I'll make it, but I need to know....the vertical end of the L shaped bracket faces towards the front of the car, or the rear. And, how far from a bolt hole to the vertical bend. This would be critical to have the seat travel the distance that Henry intended it to. I believe the 4 door models used the same mechanism. Anybody? |
09-14-2023, 10:28 PM | #3 |
I will add, if you have a curvy chrome handle , like the door handles, you have my style.
If you have a plain steel lever, thats the other type, I've had both |
09-15-2023, 08:10 AM | #4 |
Yes there are two different styles due to two Mfg for Ford. The floor mount photos below one is 32 which I believe is very similar to 34. It appears the floor mount adjuster lost favor with Ford and for 35-36 the seat mount was used and went through some changes.
09-15-2023, 08:36 AM | #5 |
Exactly what I need Terry, thank you much.
09-15-2023, 11:09 AM | #6 | |
09-15-2023, 12:11 PM | #7 |
united pacific has most of those parts advertised. and some are the
same as Model"A" richard.orlandi
36Panel Delivery |
09-20-2023, 09:44 AM | #8 |
You asked for some basic dimensions. Here they are, taken with a caliper.
This bracket is from my '34 coupe. Notice that the base of this floor bracket is angled. Should it be straight? -Mike |
09-20-2023, 09:59 AM | #9 |
Straight.
09-21-2023, 07:50 AM | #10 |
WOW ! Thats not basic dimensions, thats a blue print !. Thanks for the effort Mike.
09-28-2023, 03:58 PM | #11 |
I have the part that bolts to the floor. Yours for the shipping cost.
09-29-2023, 09:16 AM | #12 |
Thanks to all, DavidG has donated one also, in the mail I believe. Thanks again.
09-29-2023, 11:05 AM | #13 |
Yes, it went out in the mail the day before yesterday.
