Old 03-26-2023, 03:52 PM   #1
dlamm
Default A smoother ride
I carry 120 lbs of concrete in the bed of my 1930 pickup truck. It makes the ride better. Any one else tried this?
thanks : Dean
dlamm is offline   Reply With Quote
Old 03-26-2023, 04:31 PM   #2
Synchro909
Synchro909's Avatar
Default Re: A smoother ride
A VERY well know phenomenon. The ratio of sprung and unsprung weights is changed in favour of a softer ride.
Before we spend any more time working on Artificial Intelligence, maybe we should have a look at Natural Stupidity.
There is a lot of talk about leaving a better planet for the kids. How about leaving better kids for the planet?
Old 03-26-2023, 06:45 PM   #3
Brentwood Bob
Shocks are good.
Brentwood Bob is offline   Reply With Quote
Old 03-26-2023, 06:51 PM   #4
Curtis in MA
I have 150 pounds of coal in the trunk of my 30 coupe. Didn't notice much change.
Curtis in MA is offline   Reply With Quote
Old 03-26-2023, 07:00 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
300 lbs of cement on each running board works too, don’t even have to lift them, i pull up to the trough and cut the top off the bag.
Old 03-26-2023, 07:15 PM   #6
eagle
eagle's Avatar
Thats an advantage I have with the Fordor. Heavier body = smoother ride. I notice the difference vs coupe.
Old 03-26-2023, 07:19 PM   #7
nkaminar
nkaminar's Avatar
Also depends on the spring/shock system. My Fordor has aftermarket tubular shocks in back which makes for a choppy ride at low speeds. OK at higher speeds. You can adjust the stock shocks. You should adjust them for the season, summer vs. winter.
