Old 07-27-2020, 05:15 PM   #1
STAN WHITE
Default 34 ford gas tank bolts
I have had two original 34 fords. my question is, why the bolts that hold the gas tank in place on both cars . The rear bolt on the drivers side has a bolt like the radiator hold down. Bolt with a heavy spring and castle nut and carter key. My question is why. As i have no idea. Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 07-27-2020, 05:18 PM   #2
lotsagas4u
Default Re: 34 ford gas tank bolts
Frame flex for gas tank movement.
lotsagas4u is offline   Reply With Quote
Old 07-27-2020, 06:28 PM   #3
DavidG
DavidG's Avatar
To protect the gas tank when the frame flexes.
