10-17-2020, 02:51 PM | #1 |
Distribution block for 6 volt
I am looking to add a 6 volt distribution block for my 6 volt 31.
Does anyone have any recommendations on blocks or tips for adding one. |
10-17-2020, 04:24 PM | #2 |
Re: Distribution block for 6 volt
Brattons sells the A panel. Attaches to the inside firewall. Hard to work on up there but can't be seen.
10-17-2020, 04:45 PM | #3 |
10-17-2020, 04:55 PM | #4 |
In addition to the Bratton fuse block, any local auto parts store should have one for about $10.
10-17-2020, 05:43 PM | #5 |
10-17-2020, 07:00 PM | #6 |
10-17-2020, 09:33 PM | #7 |
This is what I did.....
10-18-2020, 08:18 AM | #8 |
10-18-2020, 09:55 AM | #9 |
10-18-2020, 12:18 PM | #10 |
10-19-2020, 04:51 PM | #11 |
Besides the usual single fuse block mounted off my starter switch. I attach one on my generator off of a cut-out mounting screw. This protects the main electrical system from the headlights/horn in case they develop a short. The single fuse blocks will mount on either side of the starter switch. So you can run two single blocks off of it. Also, look on eBay I've bought "antique'y looking*" multiple fuse stand alone blocks off of it.
Bob-A *I try and stay "period correct" when I modify my "A". If it is not possible then the item I use. I try and make it look "period correct" or antique'y, as I call it. |
