Old 10-13-2020, 10:01 AM   #1
Lawson Cox
Lawson Cox's Avatar
Default NOS front brake drums
While going through my stash of parts I found some NOS front brake drums. One 36-39 wide 5, and two what I believe to be 40-48, I'm not exactly sure, they are up on the top of the office ceiling and I can't really see them clearly without taking them down, and I need help to do that. It's tough to get old. I know they're hen's teeth, but what is a ballpark value by the each. Thanks for the help fellows. I appreciate it. Sorry I can't post pictures.
Old 10-13-2020, 10:51 AM   #2
Tim Ayers
Default Re: NOS front brake drums
I gladly bought two NOS '42-'48 drums (ones with the ribs and hub on the outside) for $130 a piece. I would have paid $150.
Your wide-five drum may bring more than the '42-'48 since there have not been an reproductions on this piece I believe.
The game has changed a bit with Bolling Bros. US-made drums, but these are all cast steel and not the pressed steel centers welded to cast "rims" like Ford and, therefore, much heavier.
Tim Ayers is online now   Reply With Quote
Old 10-13-2020, 11:03 AM   #3
deuce lover
deuce lover's Avatar
Just a heads up .Wide 5, 36 fronts are different than 37-39.Will not interchange
Old 10-13-2020, 12:31 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
......and HERE's the difference! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-13-2020, 01:28 PM   #5
Lawson Cox
Lawson Cox's Avatar
My wide 5 is ribbed like the one on the left. That's 36 isn't it? Thanks.
Old 10-13-2020, 01:34 PM   #6
deuce lover
Yes '36
Old 10-13-2020, 04:37 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Note how LONG the snout is for the outer bearing on the '36. DD
T5 W/TORQUE TUBE
Old 10-13-2020, 05:29 PM   #8
35fordtn
35fordtn's Avatar
Some 1937's are ribbed, so the only way to tell is look and measure. .. So, just because they are ribbed does not make them 36's. The 36's seem to be around in NOS form... Just last week I was scrounging on my brake drum shelves and found I had 5 NOS 36's but only used on the 37-39's ... bummer..
Old 10-14-2020, 12:50 AM   #9
deuce lover
In 1937 The front spindles changed hence the shorter drum in 1937.
