Old 10-12-2016, 03:00 PM   #1
Kahuna
Kahuna's Avatar
Default Fuel/Vacuum Pump
Are rebuilding kits available for these type pumps? 56 Ford Y Block
Thanks
Jim
Kahuna is offline   Reply With Quote
Old 10-12-2016, 03:28 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Fuel/Vacuum Pump
Over the counter or even a special order at an auto parts store?
I gave up looking a couple years ago, but if you search in the Early V8 section here on FordBarn or in Hemming's Classifieds there are some folks who'll rebuild them. Ask about alcohol compatible materials.
Old 10-12-2016, 04:19 PM   #3
scicala
scicala's Avatar
I believe Charlie ny has the parts and rebuilds them. He's on the Ford Barn. It's possible he may just do flathead pumps though. Not sure.
Sal
scicala is offline   Reply With Quote
Old 10-12-2016, 07:43 PM   #4
Kahuna
Kahuna's Avatar
Thanks. Guys
Not sure I need it, but looking for a source
Jim
Old 11-25-2016, 05:17 PM   #5
mobileparts
Just came upon your request... I have the Fuel Pump -- NEW -- with new modern gaskets that are ethanol gas compatible -- and I can supply you with rebuilding kits , also, with ethanol gas compatible material in the fuel pump kit.....
Call me -- Craig -- 516 - 485 - 1935... New York....
mobileparts is offline   Reply With Quote
