Old 05-19-2022, 11:18 AM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Overheating issues
Iíve got the newly rebuilt flathead back in my 40 and itís running good . Problem is itís like the farther you go the hotter it gets. With thermostats or without, block is clean, new radiator, rebuilt water pumps , timing is good. Yesterday I removed the upper radiator hoses and filled the heads with water up to the neck and removed the belt so the pumps wouldnít turn. Cranked it up and looked for bubbles in the heads, there wasnít anything there so that eliminates a leaky gasket . Before I got this car it sat in an open shed for the probably the last 20 years. Iím beginning to wonder if the exhaust could be partially blocked by mice or something. Iím at wits end with this thing.
File Type: jpeg EC29AC21-BA9B-435D-81EB-42417B826818.jpeg (151.7 KB, 67 views)
Ken/Alabama is offline   Reply With Quote
Old 05-19-2022, 01:11 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Overheating issues
Nice looking car but sideways is is hard.Try a vacuum gauge on it.It will tell you if have a choked muffler.
deuce lover is online now   Reply With Quote
Old 05-19-2022, 01:26 PM   #3
petehoovie
petehoovie's Avatar
Ken's '40...
File Type: jpg EC29AC21-BA9B-435D-81EB-42417B826818.jpg (45.0 KB, 226 views)
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 05-19-2022, 02:57 PM   #4
19Fordy
19Fordy's Avatar
Ken, Are the old radiator hoses soft and collapsing and restricting flow?
Old 05-19-2022, 03:12 PM   #5
Ken/Alabama
No, they are new.
Old 05-19-2022, 03:15 PM   #6
flatjack9
flatjack9's Avatar
A new engine will tend to run hotter at first. What about carburetion?
Old 05-19-2022, 03:28 PM   #7
Ken/Alabama
Yeah, I was expecting it to run hotter since it is all new . Took it for a 10 mile run yesterday and it was pegging the gauge when I got back home. Checked it with my temp gun and both sides were consistent 210 degrees. Best I remember the carb has .051 jets. It has the 91-99 carburetor on it.
Old 05-19-2022, 03:29 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
What do you mean " The farther you go the hotter it gets?
How hot does it get? Boil over?
Old 05-19-2022, 03:59 PM   #9
Ken/Alabama
Yes, it will boil. For example, I can drive it 2 miles down the road and back but if I were to go say 10 miles like yesterday it’ll get hot.
Old 05-19-2022, 04:52 PM   #10
Bored&Stroked
Bored&Stroked's Avatar
How do you know the timing is good? Did you put a degree wheel on it and put markings and a pointer on it?
If it continues to heat up (and the timing is right), then my guess is that either you're not pumping enough water through it, or your overall cooling capacity isn't good enough.
What type of radiator did you put in it? Also, are the water pumps ones with modern impellers (like Skip puts on them) . . . or stock type impellers?
Old 05-19-2022, 05:53 PM   #11
Ken/Alabama
No, I did not put a degree wheel on it. The camshaft is an nos Ford cam so I figured it would be good. Distributor and ignition timing was setup on my Sun distributor machine. The radiator is one of the new Bob Drake units. Pumps are stock pumps.
Old 05-19-2022, 06:17 PM   #12
19Fordy
19Fordy's Avatar
Is the radiator clean on the inside and can you see the water circulating in the radiator?
Disconnect the lower hoses and flush out the radiator with a hose to check the flow.
Old 05-19-2022, 06:26 PM   #13
Ken/Alabama
I’ve eliminated the exhaust possibility . I had an nos muffler I wanted to install anyway. I’m thinking I’ll take the radiator out of my coupe and put it in there and see how that goes. New ain’t always better. ��
Old 05-19-2022, 06:42 PM   #14
cadillac512
cadillac512's Avatar
Iíve eliminated the exhaust possibility . I had an nos muffler I wanted to install anyway. Iím thinking Iíll take the radiator out of my coupe and put it in there and see how that goes. New ainít always better. ��
Good plan. If it keeps getting hotter the further you drive, it sure sounds like radiator. 210 and steady isn't dangerous but rising from there and losing coolant/boiling is another matter. The radiator swap may be the answer.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
cadillac512 is offline   Reply With Quote
Old 05-19-2022, 09:22 PM   #15
Bored&Stroked
RE Pumps: I always run Skips pumps on my engines - as I like the way he rebuilds them (bearings, not bushings) and his impeller moves a LOT more water than the small straight impellers on original pumps. The engine in my 32 is 284 cubes and I can be stuck in traffic in 90+ degree weather (stop n go stuff) - and it won't overheat. At the Columbus Goodguy's one year I was sitting idling for about 45 minutes . . . and it passed the test with no problems (and that is with a non-pressurized system).
Old 05-19-2022, 09:34 PM   #16
Ken/Alabama
I have a pair of Skips pumps on the shelf. Iíll give them a try. Iím starting to question the repop Drake radiator. Iím thinking Iíll take the radiator out of my 40 coupe and put it in there to see how it goes.
Old 05-19-2022, 09:54 PM   #17
petehoovie
petehoovie's Avatar
What is the condition of the block innards? Was the block thoroughly cleaned out of crud?
Old 05-19-2022, 11:03 PM   #18
Ken/Alabama
Yes, shake and bake then several hours with a long pointed rod poking around in the water jackets. This block wasnít bad at all. It was pretty clean to begin with.
Old 05-20-2022, 12:01 AM   #19
Tinker
Tinker's Avatar
Have you checked your gauges. Ya stupid question.
Old 05-20-2022, 12:29 AM   #20
Tinker
Tinker's Avatar
Handy tool you can get almost everywhere.
https://www.amazon.com/Etekcity-Lase...00837ZGRY?th=1
Thread Tools
Display Modes
