Old 05-07-2022, 01:21 PM   #1
samsonized
Default flathead in a model a frame
can you install a flathead in a model a frame either a v860 or a 59ab and is there a kit to do it
samsonized is offline   Reply With Quote
Old 05-07-2022, 03:42 PM   #2
Pete
Pete's Avatar
Default Re: flathead in a model a frame
1- Yes.
2-Yes.
3- No, but there are plenty of individual parts available to do the job.
Old 05-07-2022, 04:36 PM   #3
rotorwrench
rotorwrench's Avatar
Mike Bishop and Vern Tardel's book on building a traditional Ford hot rod covers the old ways of solving the problems of the full size flathead V8. I wouldn't think too much about a V8 60 since they just don't really have the power to do much. I'd use a built banger before using a little V8 myself.
Old 05-07-2022, 08:48 PM   #4
nkaminar
nkaminar's Avatar
Rotor Wrench has a good point. With a little work and some speed parts the Model A engine can put out 90 horsepower. A little more work and more speed parts and it can put out more. See https://www.modelaparts.net/dynoshee...ynosheets.html. With the availability of the Burtz engine there is really no reason to go to a V8 unless you are looking for the cool factor.
Old 05-07-2022, 09:36 PM   #5
Art Newland
Art Newland's Avatar
I watched this video a while ago. Installing a Flathead V8 in a Model A pickup with a bolt-in kit.
https://youtu.be/QBUrzt9PUQg
"whatever works!"
Art Newland is offline   Reply With Quote
Old 05-08-2022, 03:58 AM   #6
Pete
Pete's Avatar
Flathead engines will fit in many things.
Tonight I saw an 8ba in an 8N tractor. It had Offy heads and manifold and they said it made just over 100 hp.
Old 05-08-2022, 08:36 AM   #7
rotorwrench
The Funk brothers designed a lot of things back in the day. The Funk airplane is kind of a rarity now days. The Ford tractor conversions did a lot better with both H series 6-cylinder and flathead V8 conversions being produced. Folks are coming up with similar tractor conversions in the modern era.
After watching the You-Tube on the easy bolt in, I came to two conclusions about that.
1. It's not an easy install as was advertized. The fit needed a lot of tweeking for a "bolt in" and the tweek on the front cross member took away some of the strength there.
2. It does almost nothing to reinforce an already weak frame design. The use of the 1932 K-member at least added some reinforcement to the frame as long as the legs are used on both sides. Just bolting the rear engine mount to the center cross member makes for a problematic structure. The model A engine and flywheel cover added some strength to the frame by tying into it. All that is lost when deleting that type of structural reinforcement. Even an F1 cross member or a fabricated one would be better than deleting it altogether.
Old 05-08-2022, 12:29 PM   #8
Charlie Stephens
The V8 60 is a lot less cubic inches (136) than the original Model A engine (200) and I don't think you will be happy with the result. Drive one first.
Charlie Stephens
Old 05-08-2022, 03:20 PM   #9
Step-down
Step-down's Avatar
59ab
File Type: jpeg 2B8B2663-2EE9-46B4-A61C-F2B871367DE5.jpeg (32.0 KB, 108 views)
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 05-08-2022, 03:49 PM   #10
GreenMurray
GreenMurray's Avatar
The "A-V8" is a very popular build for hot rods and speedsters alike, it certainly can be done. I have the 1952 edition of the Ford Speed Manual which is a good read for ideas.
Model A's never die, they are just missing in action.
GreenMurray is offline   Reply With Quote
Old 05-08-2022, 03:56 PM   #11
GeneBob
Who needs a V8?
GeneBob is offline   Reply With Quote
Old 05-09-2022, 01:43 AM   #12
Synchro909
Synchro909's Avatar
If that is street legal, you guys get away with anything. That would never pass engineering inspection (required before registration) with cross members cut and so much power to say nothing of brakes, seat belts, collapsible steering column etc etc. but we live in different legal jurisdictions.
You and I have been through a lot of difficult situations and they have all been your fault!
Old 05-10-2022, 07:55 AM   #13
ronn
sounds like your hands are tied Synchro
many states here you can do pretty much as you please. Heck, if a modern car here in NJ has a broken frame, but it passes pollution control- you are handed a clean bill of health!
crazy but true.
Old 05-10-2022, 08:01 AM   #14
Tim Ayers
https://www.verntardel.com/store/p28...Winner%21.html
Get this book. Best guide out there to walk you through what you want to do.
Old 05-10-2022, 09:14 AM   #15
rotorwrench
I try to stay out of anything political but I'm sure most folks would agree that free countries aren't always as free as we would like them to be. That's all I have to say about that.
On the bright side, it helps to keep things pretty stock when some changes aren't allowed. This is OK for the purist restorer. The hot rodder, not so much.
Old 05-11-2022, 08:31 AM   #16
Terry, NJ
Terry, NJ's Avatar
This is the land of the free and the home of the brave! You are free to do it and brave to ride in it! One more thing, you better be rich to weather the lawsuits that may come out of inadequate engineering. I recall a show on tv called "American Hotrod" where the owner (Can't recall his name , but he was a famous Hollywood builder) Got into a tussle with one of his employees over boxing a 32 Ford chassis that was the guy's own car. I think he fired the employee. Now I have the name, It was Coddington!
Terry
Terry, NJ is online now   Reply With Quote
Old 05-11-2022, 09:12 AM   #17
jack backer
So much power? A flat head V8?
A modified flathead A or B engine develops almost the same hp and torque.. with a much quicker torque rise.. the time and money you spend on a V8 sure is a let down the first time you drive it.. not to mention it’s crack prone and you fight overheating issue..but hey, it sounds sexy..
Looks like not everything is better in OZ..
jack backer is offline   Reply With Quote
Old 05-11-2022, 10:04 AM   #18
Tim Ayers
A modified flathead A or B engine develops almost the same hp and torque.. with a much quicker torque rise.. the time and money you spend on a V8 sure is a let down the first time you drive it.. not to mention itís crack prone and you fight overheating issue..but hey, it sounds sexy..
A highly modified flathead V8 can easily double the power of the same highly modified A or B banger. 80-100 hp vs. 180-200 hp.
Now, if we are talking OHV conversion to said banger, know you've got my attention.
Different strokes for different folks....
Old 05-11-2022, 10:42 AM   #19
jack backer
No doubt Tim modified to modified..hopping up a banger is Walmart, a V8 is Nordstrom. Wallet accordingly..
Old 05-11-2022, 10:48 AM   #20
Tim Ayers
Haha. Great analogy. To be clear, there nothing wrong with a hopped banger. Heck, my buddy's full race banger sounds outright angry and goes like stink.
That said, no modified flathead is cheap to build. Do it right once.
To your point though, more power, more problems or things that need to be changed to handle the power.
Thread Tools
Display Modes
