Old 02-04-2019, 11:19 AM   #21
DelPercio
Default Re: Battery in wrong
I want to thank everyone for their help. I called the seller and he said they didn't touch the battery and looking at a video they made the amp was charging so I'm leaving it negative ground.
DelPercio is offline   Reply With Quote
Old 02-04-2019, 11:38 AM   #22
redmodelt
redmodelt's Avatar
Sounds good. If you are having issues with charging it, might be the charger or battery. You could take the battery to an auto parts store and have it tested.
Old 02-04-2019, 12:26 PM   #23
Purdy Swoft
Purdy Swoft's Avatar
Batteries can explode when hooked up wrong . If it is charging it should be good .
Old 02-04-2019, 04:12 PM   #24
100IH
Best to do the electrical as original so the next person won't have a mess to deal with and have to figure it out. Mark the cables and posts with red and black so anyone could attach a charger W/O being injured. Your choice on what to use for ground only know that it was always pos. to ground. Bulbs, starter, don't care and generator if re-polarized dosen't care either.
100IH is offline   Reply With Quote
Old 02-04-2019, 06:01 PM   #25
Purdy Swoft
Most all vehicles are now negative ground . Most people have never heard of positive ground so they just make a razoo and connect the cables wrong .
Old 02-05-2019, 12:54 PM   #26
Patrick L.
Patrick L.'s Avatar
The amp was charging in the video ? So how is the ammeter acting now ? If it is acting as it should, then it can be left alone if you like.
Old 02-10-2019, 03:45 PM   #27
zzlegend
zzlegend's Avatar
I have never seen a starter run backwards. Does that mean its sucks the varmits in thru the exhaust and pukes them out the carb? Just curious,,, i am old senile.
zzlegend is offline   Reply With Quote
