08-15-2015, 03:52 AM | #1 |
Sedan seat
On my 30 sedan , the passenger seat irritates me when I am by myself ,
Every time I come to a stop , the seat Back flips down , Is there a way to tighten the seat back so it does not flip , was there springs that Attach the bottom to the top to keep it from flipping ? |
08-15-2015, 05:15 AM | #2 |
Re: Sedan seat
There were no springs. I suppose you could use a bolt and lock nut at the hinge and tighten it.
Sounds like you have good brakes. Just how fast are you stopping? |
08-15-2015, 06:39 AM | #3 |
Re: Sedan seat
mine did the same thing until i added the 6" seat adjusters for leg room. they also have an adjustment for tilt which stopped the seat back from folding on stops.. it was annoying
08-15-2015, 12:07 PM | #4 |
Re: Sedan seat
SOLUTION: Let your Dog go too !
Bill W.
08-15-2015, 04:14 PM | #5 |
Re: Sedan seat
Tom , stopping Is normal , I do have good brakes ,
I have removed the rear legs to give it a more recline back , Both pin's @ the hinge have a groove cut in them opposite end of the head , I was thinking there was a spring attached up in back rest & down to pin , Would a E clip have been used on the pin from Ford? |
08-15-2015, 07:54 PM | #6 |
Re: Sedan seat
08-15-2015, 08:03 PM | #7 |
Re: Sedan seat
Put a round flat wavy spring washer between the seat frame that pivots. you can purchase at ace hardware
08-16-2015, 09:18 AM | #8 |
Re: Sedan seat
Yes, that groove in the pin should have an E clip or a wire ring. I think my seats used the wire ring.
08-16-2015, 07:45 PM | #9 |
Re: Sedan seat
Thank's for all , I did not think of the wavy washer ( obvious )
I Will try ! I am surprised that Ford did not use somekind of Detent to pervent the back from folding over. |
