Old 05-14-2014, 12:50 AM   #1
alrogers
Default 33 dash engine turning, does anyone make one? Or a thin engine turned material?
Where can I buy a 33 dash with engine turning that I can use the original guages in?
Or who makes a this metal turned material that can be attached to an original 33 dash insert?
All leads appreciated!
Al Rogers
alrogers is offline   Reply With Quote
Old 05-14-2014, 05:32 AM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: 33 dash engine turning, does anyone make one? Or a thin engine turned material?
Here's an old HAMB thread on the subject (Google is your friend): http://www.jalopyjournal.com/forum/t...luminum.92762/
4dFord/SC is offline   Reply With Quote
Old 05-14-2014, 07:19 AM   #3
G.M.
The material is aluminum and can be "engine turned" on a drill press. You need a guide that can be moved to keep the swiriles in line and you nest the next row like stacking oranges. Takes a little time but not difficult. G.M.
www.fordcollector.com
Old 05-14-2014, 10:29 AM   #4
hotcoupe
hotcoupe's Avatar
this is a `32 panel that i engine turned. contrary to what has been posted above, the original panels were carbon steel that was copper, nickel plated, engine turned and then chrome plated. to engine turn nickel requires a special technique, otherwise the nickel will "smear" instead of "cut". i can restore your panel to the original condition, please P.M. if interested.
tom
hotcoupe is offline   Reply With Quote
