02-02-2015, 11:39 PM | #21 |
Re: 90% Oil Filtering Fitting
I did one on a 37 block
02-03-2015, 12:08 AM | #22 |
Not all of even the later blocks have the flat spot cast into them, it does not make any difference in the modification.
02-03-2015, 10:42 AM | #23 | |
Here is an article on this taken from Bill B's Tecno Site: http://www.flatheadv8.org/filter.htm
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-03-2015 at 05:12 PM. |
02-03-2015, 11:31 AM | #24 |
OK, I know that filtered oil is better, but is this necessary? Say if one is diligent and changes the oil regularly (say every 1,000 to 1,500 miles).
02-03-2015, 11:36 AM | #25 | |
The "H" fitting shown on Meric 42 post of the Canadian military full-flow is the the filter by-pass needed for cold start oil circulation. The fitting that blocks the horizontal passage has an integral 1.25" thinwall brass tube that extends down past the horizontal connecting passage. The top of that fitting connects the 3/8" ID line to the filter. This same fitting was used on the post-war Ford Canada option that used 3/8" ID hard lines from '46 to '48 and 3/8" ID hose on the '49 '51 version. This fitting would always have to be removed to plug the block openings to run without filter, or change back to the bypass type. No surprise grub screw that might be missed later. ..B. |
02-03-2015, 11:55 AM | #26 | |
02-03-2015, 12:31 PM | #27 |
many of the full flow wartime engines were for Bren carriers which had an oil cooler rather than a full flow filter...a little flathead pulling around an AFV had to run at full throttle most of the time. Many Canadian built trucks and gun tractors had the filters and PCV setups.
As far as I can tell, USA wartime engine picked up the little boss as part of assuring interchangeability of resources, since some USA flatheads were fed into Canadian production during the war. By the way...if you read through Ford's own 1937-48 engine rebuild book, you will note that the pictures are of a wartime engine that has full flow...you can see the three fittings in one of the pictures. |
02-03-2015, 02:48 PM | #28 | |
Im gonna be using one on my truck when it gets a fresher engine. But only as I have the Canadian military bits (except the H bypass bit, but some/lots of spin on filters have one built in, so I won't pay it any mind) The stuff I have I pulled of engines I've rebuilt and they didn't want them bits. This is the style with a thinwall fitting that covers the hole, not the grub screw style. I also have the Donaldson crankcase ventilator (PCV) that I may fit if it don't bugger about with the Southwind heater. If I didn't have the bits to hand, I'd use the stock Ford oil filter, bypass style. It worked for years and that's ok by me. Do folk really change oil every 1000 miles? If you do 2000 miles a year, that maybe ok, but if you do proper mileage it seems excessive to me. Martin. |
02-03-2015, 02:51 PM | #29 | |
02-03-2015, 05:28 PM | #30 |
Is an oil filtering system necessary on our modern cars? I don't recall seeing any cars built since the 50's that did not have an oil filtering system. Do we really need it if we routinely change the oil at maybe some logical interval? Would we even think about eliminating the oil filter and saving on the cost of buying maybe 3 to 4 oil filters each year?
02-03-2015, 06:44 PM | #31 | |
02-03-2015, 08:00 PM | #32 | |
How many hours of running said mower, does that translate..... So say I mow my lawn once a week from spring through fall...I have 35-40 hours on the engine. Heck, you could do that in a automobile in a week. Other issue (as was brought up above, not by you Tim) is modern vehicles are fuel injected, the fuel entering the engine over the past 15 years or so, is precise, as is the timing, load adjustments, etc...nothing like even the "best" carb'ed engine could ever achieve...which lead to fuel fouled oil eventually. Even if driving a carb'ed engine under ideal, no dirt, dust environment, the oil will contaminate and needs to be serviced. |
02-04-2015, 02:54 AM | #33 |
I'd like to add some weight to the pro oil filter side. Just cus of the devil's ardvercut (sp?) The Ford Popular (Anglia) 103E, came stock over here with no air filter, just a lid over the carb, and no oil filter up to 1959. The engine life expectancy was about 30000 miles before major rebuild, including re bore and crank grind.
For the modern properly filtered engine, 100 000 miles is a walk in the park. I know oils are better, running temperature is higher and proper pcv systems do a chunk of the longevity job, filtering does its fair share too. Martin. |
