09-14-2013, 10:39 AM | #1 |
90% Oil Filtering Fitting
Not long ago during a discussion of how to achieve 90% oil filtering, someone posted the attached figure.
I'm considering having the fitting made by a local machinist and I would like the dimensions of the fitting. Can someone help? Thanks, dw
I love this country; it's the damn idiots running the government I'm afraid of. |
09-14-2013, 11:16 AM | #2 |
Re: 90% Oil Filtering Fitting
You don't need any special components to do this operation. There have been several articles published on line and in books (Mine) that explain the easy way of doing this. Just install a set screw in the passage way between the two lines. This will permit the oil to go directaly to the filter and return to the oli system of the engine. Simple.
09-14-2013, 12:29 PM | #3 |
Like Ol'Ron says tap and install allen set screw
09-14-2013, 12:41 PM | #4 |
U.S. built flatheads need to have the inboard vertical oil port drilled and tapped to provide the extra passage from the filter, and tapping the horizontal passage for the grub screw that isolates the outflow from the inflow can be easily done at that time, since the engine is out of the car. The Ford Canada built flatheads already have the inboard passage drilled and tapped, thus a fitting to isolate the "in" from the "out" without drilling or removing the engine can be designed such as this one. Ford Canada used a thin brass sleeve that projected down from the outboard vertical passage about 1.25" to block the horizontal flow, and it was part of the fitting that connected the 3/8" ID line to the filter so that if the filter was removed and the ports blocked to run with no filter, the horizontal passage was clear and no possibility of forgetting to remove a blocking device. The full-flow option could be provided quickly by the dealership without machine work and little possibility of problems caused by later removal or change to a bypass system. ..B.
09-14-2013, 02:25 PM | #5 |
I'm aware that I could drill and tap the inside passage for a set screw. i'd like to make this modification without needing to drill and tap with attendant risk of contaminating the oil system. I'm not in the process of rebuilding the engine or anticipating doing same. The beauty of the "plug" I inquired about is that it appears it could be inserted without any need to drill and plug.
If I were reworking the engine I would certainly do the drill and plug procedure, but I'm just trying to get better filtration without needing to tear the engine down. dw
09-14-2013, 02:36 PM | #6 | |
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-14-2013 at 02:42 PM. |
09-14-2013, 02:37 PM | #7 |
Don, you're aware that the second vertical hole will still have to be drilled and tapped unless you have the Canadian block that already has that hole?
Alan |
09-14-2013, 04:42 PM | #8 |
Thanks to all for illuminating the errors in my thinking. Another brain storm deflated by reality! Argh.
dw
09-14-2013, 05:44 PM | #9 |
There is a guy in Canada that makes that grub screw just like the one in the pic. Cheaper than having a machine shop make one. There is a rubber O-ring that seals that inner passage, you can see it in the pic. Someone on here has his name and no. Walt
09-15-2013, 07:54 AM | #10 |
The fellow that was selling the plugs shown is
Bryan Buckley 5649 Marlatt Ave Powell River British Columbia Canada V8A 4E6 His Email is [email protected] All this info is dated so I hope it is still currant. |
02-02-2015, 04:14 PM | #11 | |
02-02-2015, 04:21 PM | #12 |
I've always drill and tapped those holes 3/8 pipe thread, But I've seen the Canada ones are drill only for 1/4 pipe thread, I guess you have to get a 1/4 fitting with the biggest hole that you can find and it will get enough oil through to feed the engine. Walt
02-02-2015, 04:38 PM | #13 |
There was a post here 2/3 years ago, about a guy who drilled, taped, and added the threaded set screw to his block as necessary to have the 95% FF system. He wanted to fire the engine for its initial start up without the oil filter and lines plumbed, so he just blocked off those rear ports with threaded pipe plugs. He fired the engine, let it run for awhile, took a ride and the engine seized. Bearings and I believe some bearing journals were damaged. Problem turned out to be no oil flow to some or all main and rod bearings. If he had done this using that Canadian plug design and removed the plug until he was reading to install the filter and lines, this would not have happened. It was a tough and costly way to learn
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-03-2015 at 10:12 AM. |
02-02-2015, 04:56 PM | #14 |
JM, I remember the historical post you are referring to and I seem to remember the problem was caused by the grub screw being in place in the passage. (from a previous oil filter conversion). the problem wouldn't have been averted by a plug like above (unless you are referring to removing that type of plug).
Mart. |
02-02-2015, 06:01 PM | #15 |
I have a motor that is out of the car and on a stand. Doesn't need to be rebuilt and runs fine as is. Would it be a mistake to try to perform this modification without taking the motor completely apart? What about partial dis-assembly, if the chance of oil contamination with metal shavings is an issue? Magnetic probe after tapping? What about temporarily blocking the oil passages until all the necessary machining procedures and appropriate cleanup has been satisfactorily completed? Perhaps I should leave it as is, but it would be a worthy mod to do if I could eliminate a total tear down/reassembly from the process. What do the FB gurus think?
John M |
02-02-2015, 06:19 PM | #16 | |
EDIT: Well, I went back and found the thread I was thinking about. As it turns out, on the Canadian system and plug with an o-ring, you would need to removed that plug, same as would the grub/set screw if that method was used, if you wanted to run the engine before the filter and lines are install, and if those holes were plugged. Here is the post with lots of reading but some very important reading for those who are planning to do this type of 95% FF oil filter system. http://www.fordbarn.com/forum/showth...lter&showall=1
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-03-2015 at 01:21 AM. |
02-02-2015, 06:32 PM | #17 | |
02-02-2015, 09:56 PM | #18 |
Hey all, have any of you done this on a 21 stud engine? I have a 36 and was reading the past threads and after looking at my block on the stand it does not have the convenient flat spot in the casting like the later engines. Finding the oil passage is easy but I am concerned that due to the curvature of the casting in that area I will not have enough material depth to get a good set of threads cut for the second fitting.
02-02-2015, 10:16 PM | #19 |
FYI Here is the information on the Canadian Military setup
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
02-02-2015, 10:45 PM | #20 |
Another option is to use the true full flow conversion which needs no modifications to the block; although a hole must be drilled in the side of the pan. There's details on my web site and a kit is available here:
http://www.flatheadspeedandmachine.c...sion-kits.html Also do a search for Motor City Flathead full flow filter. |
