08-21-2013, 03:47 PM | #1 |
battery cable--what guage?
I need a new cable from the battery to the starter, 6 volt. I don't understand the numbering system for the wire guage for these cables.
1. Is this the correct order, for the largest to the smallest? #1 0 00 000 etc. 2. Is 2/0 the same as 00 ? 3. Snyder's has the cable, 2/0. Material not specified. Bratton's has the cable, #1 copper. Is #1 larger than 2/0? Is larger cable better? Is copper better? Which one do I want? Thanks for your help. W, Michael |
08-21-2013, 04:02 PM | #2 |
Re: battery cable--what guage?
Wire size chart
08-21-2013, 04:17 PM | #3 |
I believe that #1 is the original size. I've kinda subscribed to the 'bigger the better' theory. I prefer #0 or #00. If your friendly local Tractor supply store doesn't have any, then, the welding store will.
08-21-2013, 05:56 PM | #4 |
The smaller the number, the larger the wire. 00 is larger than 0; 000 being larger than 00, etc. 1/0 = 0; 2/0 = 00; 3/0 = 000; etc
Have I confused you enough yet?
08-21-2013, 06:19 PM | #5 |
Well, no wonder I'm confused. 000 steel wool is finer than 0 steel wool, but 000 wire is courser than 0 wire. Thanks for your help--although I may remain confused!
08-21-2013, 07:30 PM | #6 |
08-21-2013, 08:07 PM | #7 |
yea with battery cables and ground straps: bigger is better and can never have enough grounds. Yes there is a point where the improvement is negligible but it would in theory be better.
I agree with bill. at work we have 4/0 weld cable, its like lugging around a 3/4" garden hose filled with concrete... 2/0 would be perfectly fine for battery cable. especially since it only has to travel the less than 3 feet.
08-21-2013, 08:42 PM | #8 |
If you want to be even more confused, the current flows on the outside of the wire, the more strands the more amp the cable can handle. Or so I have been told.
08-21-2013, 09:18 PM | #9 |
I would just buy the battery cable already made from one of the Model A parts dealers. They fit, look, and work fine.
08-21-2013, 09:30 PM | #10 |
If you look to buy a ready made cable from a parts store take a magnet with you, some of the ready made cables have steel terminals ---they get bad internal connections quick.
08-21-2013, 10:15 PM | #11 |
For my 1930 coupe with 6 vDC system, I use "1/0 Battery Cable" (stranded copper) and copper lugs, both recently purchased from Napa Auto Parts.
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. Last edited by Napa Skip; 08-21-2013 at 11:49 PM. |
08-22-2013, 12:56 PM | #12 |
Thank you everyone for your help. I ordered the ready-made 2/0 cable from Snyder's.
W. Michael |
08-22-2013, 01:38 PM | #13 |
I read somewhere to think of current flowing through a cable like blowing air through a pipe. Blowing air through a 4in. pipe with your mouth is not as effective as blowing the same amount of air through a 1in. pipe. Or was it water through a pipe? I guess it's the same principal.
08-22-2013, 02:56 PM | #14 |
Where else would Napa Skip purchase his parts?
