Old 10-12-2020, 01:36 PM   #1
johnbuckley
johnbuckley's Avatar
Default U joint felt seals.. how do you fit them?
How do you get these felt seals to fit neatly in the groove of the "clam shells" . The new felts looks far too big and loose in their uncompressed state.
Old 10-12-2020, 04:07 PM   #2
Herb Concord Ca
Default Re: U joint felt seals.. how do you fit them?
The felt seals should be rectangular not square. The narrowest width should fit into the clam shell slots with a little help.
Herb Concord Ca is offline   Reply With Quote
Old 10-12-2020, 06:23 PM   #3
1crosscut
1crosscut's Avatar
I've cut strips of cork gasket material to lay in the groove to take up some of the space making them fit tighter. I use a little bit of silicone gasket maker to stick the cork into the bottom of the groove and a bit of the same to stick the felt to the cork. This makes for a better compression fit when assembled. I do not use the gasket maker on both sides of the felt so it still has the ability to move/slide as needed while going down the road.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-13-2020, 08:23 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Try soaking the felts in motor oil.
Bob Bidonde
Old 10-13-2020, 01:29 PM   #5
john charlton
john charlton's Avatar
I took the back axle and drive line out of a 29 tudor which had been flooded for a week or so ,halfway up the windshield in fact . The vehicle had been in one family since new and had 76,000 miles on it . It had never been apart I would bet . There was no felt in the clam shell grooves just a tight fitting cork seal . I never have much success with those fluffy felt seals poked prodded greased etc etc etc I tried cork in my 28 phaeton and no leaks (yet !!!)
John in rainswept Suffolk County England .
Old 10-14-2020, 07:22 AM   #6
Grier
I have used this. It is working for me. O-ring upgrade.
https://www.ebay.com/itm/Model-A-For...AAAOxyY9VRQWmB
Grier is offline   Reply With Quote
Old 10-14-2020, 10:37 AM   #7
DBrer
I use the o ring upgrade also and have not had any leaks.
DBrer is offline   Reply With Quote
