Old 12-02-2019, 08:49 PM   #1
tinman7
tinman7's Avatar
Default Low to High Gear
Wondering the cause of chatter from low to high gear it smooths out when fully engaged. Any thoughts?
tinman7 is offline   Reply With Quote
Old 12-02-2019, 09:25 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Low to High Gear
Maybe not letting the low pedal up smoothly or not backing off the throttle when you up shift.
Old 12-02-2019, 10:54 PM   #3
Scottio57
Scottio57's Avatar
I’ve noticed not everyone will back off the power when engaging high gear. You should. Also believe it or not I changed from generic to Valvoline oil and it made the the clutch smoother.
Scottio57 is offline   Reply With Quote
Old 12-05-2019, 09:25 AM   #4
richie rich
My 23 dose the same thing its really bad the hole front end shakes bad double clutch back off the throttle then it bogs and slowly picks up speed top out about 50 on my phone app not good emr brake high speed backs off about 5 clicks have to hold with foot will replace ratchet and paul today o what fun Santa at maricopasants.com
richie rich is offline   Reply With Quote
Old 12-05-2019, 10:57 AM   #5
Royce P
Royce P's Avatar
This is caused by either driver technique or a weak clutch spring, or both.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 12-05-2019, 10:09 PM   #6
richie rich
yeah week clutch spring i thought about that a parts suppler sells a part that goes between the spring looks like a quick fix till next year when i tear down and inspect there are a few things i want to do
Old 12-08-2019, 07:51 PM   #7
thom
thom's Avatar
Our '21 Touring did the same when I first started driving it.
No more...It either got "broke in" or I learned how to drive it. Just saying...
thom is offline   Reply With Quote
