Old 10-22-2019, 09:37 AM   #1
DelPercio
Default Drain plug
Trying to change transmission fluid on my car that has 3200 miles showing. The fill plug loosened easily but I can’t get the drain plug off. I’m afraid to put heat on it because of all the oil underneath. Before I put a pipe wrench with a cheater bar I want to make sure it’s left loose and right tight
DelPercio is offline   Reply With Quote
Old 10-22-2019, 09:53 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Drain plug
It is right hand thread. If the plug loosened easily then what is happening ? Why won't the plug come out ? I wouldn't be afraid of heating the transmission case or plug.
Old 10-22-2019, 09:55 AM   #3
DelPercio
The fill plug loosened easily but the drain plug even with some oil dripping off of it won’t loosen.
Old 10-22-2019, 11:49 AM   #4
WHN
Turn left to take out. Someone over tightened nut. Do not use heat. Just use the “right” wrench. Take your time.
Old 10-22-2019, 12:28 PM   #5
Patrick L.
Patrick L.'s Avatar
Oops, my mistake. If its that tight still usually a big ass wrench along with a whack of a bigger hammer or cheater should break it loose.
Old 10-22-2019, 12:28 PM   #6
johnbuckley
johnbuckley's Avatar
sometimes seized components respond better with a sharp tap from a hammer onto the wrench rather than extended leverage
Old 10-22-2019, 12:47 PM   #7
ryanheacox
ryanheacox's Avatar
A little "percussive maintenance" should break it loose.
When in doubt, get a bigger hammer. And if that doesn't work the problem is electrical
Old 10-22-2019, 03:33 PM   #8
DelPercio
Used a 10 inch adjustable wrench while hitting it with a hammer. I’m surprised it’s so tight because there’s oil dripping off of the plug. I think I’ll wipe it down good heat the plug then try a pipe wrench. Just wanted to make sure it’s a right hand thread.
Old 10-22-2019, 03:42 PM   #9
Charlie Stephens
The oil dripping is probably the clue. The previous person kept tightening it until the leak stoped (which it didn't). You will probably need at least a new plug. Maybe the threads in the plug were cut undersize by mistake. You might get by with thread sealent.
Charlie Stephens
Old 10-22-2019, 03:59 PM   #10
Don Turley
Don Turley's Avatar
The drain plug is a right hand pipe thread. Since the pipe thread is tapered, and with the plug over-tightened and still leaking, it is possible that the transmission housing is cracked at the drain hole. Clean it good and check with a thinner liquid (water or mineral spirits) before filling with new oil only to find it is still leaking.
Don Turley is offline   Reply With Quote
Old 10-22-2019, 04:00 PM   #11
Patrick L.
Patrick L.'s Avatar
Sounds like a bigger wrench and bigger hammer are needed. It usually takes a big sharp rap to get things moving. I also wouldn't be afraid to use big heat on the case around the plug.
Old 10-22-2019, 08:04 PM   #12
Bill Cilker
Bill Cilker's Avatar
good opportunity to purchase a 12" or 15" adjustable wrench
You probably need to start with a bigger wrench.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 10-22-2019, 08:21 PM   #13
ursus
This sounds all too familiar to me. A previous owner had cross-threaded the drain plug and responded to the resulting leak by twisting the plug so tight that he cracked the case, which allowed for even more leakage. I had bought this car as a "barn-find" and soon after found the transmission to be completely empty of oil. I hope your situation is not a bad as mine.
Old 10-23-2019, 02:38 AM   #14
Ak Sourdough
Ak Sourdough's Avatar
My first choice would be an 8 point socket to fit the square head of the plug and an impact wrench. Hopefully the square isn't all rounded over from removal attempts. If it is, a pipe wrench is probably your best bet. Likely you'll find it cross threaded and/or a cracked case. Good luck.
Ak Sourdough is offline   Reply With Quote
Old 10-23-2019, 07:40 AM   #15
chrs1961815
chrs1961815's Avatar
To take drain plugs off, I have a set of square drive sockets that I use where one (can't remember the size) fits perfectly. No rounding it off then.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-23-2019, 07:40 AM   #16
Joe K
Joe K's Avatar
If the crack does not "extend" - the transmission can be removed, the contents taken out, cleaned and blasted, and either brazed, or simply paint the inside with "Glyptol" which is a red paint-like substance used frequently in electric motor rebuilds.
Formally an "insulating varnish" Glyptol is alcohol based, paints on, and once set is IMPERVIOUS to oil. Many race car internals are painted with Glyptol simply to seal the cast iron case-work against foundry grit coming loose inside the case and ruining an engine or gear train. It keeps the box cleaner in service (cleanliness is next to longevity in machines) and makes service and subsequent cleaning faster and easier.
Glyptol has some inherent flexibility - its used on electrical windings which can move under the magnetic flux of a motor - so when you reinsert the plug and tighten, even though you may spread the crack a bit, the Glyptol will likely bridge it and seal.
Brazing may be a possibility for repair - but like me trying to braze a cracked iron pot, once the crack starts it may be impossible to stop - you may chase that crack all the way up into the bearing recesses - in which case it's junk.
New cases are around. I have at least two extra transmission cases here. You'll pay more for shipping than the case and possibly the entire transmission will sell for at an antique auto flea market.
Joe K
Shudda kept the horse.
Old 10-23-2019, 07:44 AM   #17
Patrick L.
Patrick L.'s Avatar
Problem with a crack, stop drill it.
Old 10-23-2019, 10:38 AM   #18
katy
katy's Avatar
First, hit the end of the plug a few good blows w/a fair sized hammer, then work on turning it.
Old 10-23-2019, 01:20 PM   #19
Purdy Swoft
Purdy Swoft's Avatar
I wouldn't beat on the drain plug too hard .
Cast iron threads don't give like steel threads .
Replacing the transmission case isn't an easy job .
The back end would have to be removed first . .
I would use the pipe wrench .
If the handle of your wrench is too short , slip a longer pipe over the handle for added leverage .
Be careful not to jerk of knock the model A off of the stands while you are under it .
If heat is used , heat the case around the drain plug rather than the plug its self like Patric k L suggests .
If the plug is first heated , expansion from the heat can also cause the drain plug to expand and get tighter .
Old 10-23-2019, 03:09 PM   #20
ETAModel
When in doubt, get a bigger hammer. And if that doesn't work the problem is electrical [/QUOTE]
That's Priceless !!!!!
ETAModel is offline   Reply With Quote
