Old 06-12-2015, 12:29 PM   #1
wbs
Default remove quater panel, how to
hello,trying to remove quart panel from 28 phaeton , have removed all visble rivets and bolts [front, middle and back and those connected to the seat frame] and after doing so, the front half is loose but the back half is not. the item is very rusty, but i drilled thru 3 what may hve been tack welds[hard to tell due to rust] on the back half but still no loosenig
ques 1 any ideas on what i'm overlooking? or what else to do?
ques 2 were there tack welds in 1928 and am i missg more other than 3?
thanks
wbs is offline   Reply With Quote
Old 06-12-2015, 12:43 PM   #2
Rowdy
Default Re: remove quater panel, how to
I am not sure on the phaeton, but on the tudor quarters I removed there were more than 3 spotwelds in the wheel well area along the subrails. I was thinking 6 of them. Look in my delivery sedan picture album. Maybe some of the pic's I posted will help. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 06-12-2015, 02:30 PM   #3
wbs
thank you - you are right , i found 6 or 7 ---as i moved along finding points of resistance , i found some that were not visible---the other thing i found was that the welkds were bigger than i expected and some were eccentric so they still held the panel on- had i known i probably would have bought a large tack cutter at harbor freight --in any case the panel is now off after too many hoursv trying to find the fastners thanks again
