Old 04-26-2021, 08:57 AM   #1
rottenron36
rottenron36's Avatar
Default 1936 Temp gauge with red die, special fitting
I have a temp gauge with the red die. When I went to install it in my 59AB, The fitting fits but there is nothing to hold the bulb in place. I believe it to be a 1936 gauge and want to use in my 36 pickup. Is there a special fitting for that purpose, otherwise is there another way or place to install it? Thanks Ron
rottenron36 is offline   Reply With Quote
Old 04-26-2021, 11:33 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 Temp gauge with red die, special fitting
You are missing the adapter.Southside Obsolete in MN,35tn both members here has those I'm sure.
deuce lover is offline   Reply With Quote
Old 04-26-2021, 11:59 AM   #3
marko39
Are you missing the nut that holds the bulb in?
marko39 is offline   Reply With Quote
Old 04-26-2021, 12:59 PM   #4
rottenron36
I have the nut above the bulb, but nothing to keep the bulb in place and seal it. Ron
Old 04-26-2021, 01:11 PM   #5
marko39
You should be able to buy those fittings. I have used them from an aftermarket water gauge kit. (after I cracked mine from overtighting)
Old 04-26-2021, 01:36 PM   #6
rottenron36
Got one coming from 3rdgen. Thanks all
