Old 03-20-2021, 05:35 PM   #1
ropot
Default Model A decklid/ rumble seat lid bumper
I usually do well with this sort of item, but this one has me defeated. How in the world do you install these?
ropot is offline   Reply With Quote
Old 03-20-2021, 05:43 PM   #2
40-A Twins
40-A Twins's Avatar
Default Re: Model A decklid/ rumble seat lid bumper
Coat the end with a dab of liquid dishwashing soap, and you have to twist and push real hard to get those on. Your post reminded me of the difficulty I had installing the same bumper years ago.
Kevin
40-A Twins is offline   Reply With Quote
Old 03-21-2021, 07:29 AM   #3
McMimmcs
McMimmcs's Avatar
There is a lubricant in the ladies section at the pharmacy that is good for many things! This is one of them! Wayne
McMimmcs is offline   Reply With Quote
Old 03-21-2021, 08:33 AM   #4
KenBolton
They are a real challenge to get in. Then you may have to grind them down if the lid sits to high.
KenBolton is offline   Reply With Quote
Old 03-21-2021, 10:14 AM   #5
ropot
🤣 or perhaps just glycerin.
Old 03-21-2021, 12:24 PM   #6
Gary Karr
Gary Karr's Avatar
You might also remove excess paint along the rim of the holes, which might give you a bit more room to work the rubbers into.
Gary Karr is offline   Reply With Quote
Old 03-23-2021, 07:02 PM   #7
ropot
Thanks for the suggestions. I got all 4 in. lube and twist, and press ( al lot of each). I got some assist from a ratchet clamp that I use for carpentry projects, that helped a lot. Lid fits great now.
Old 03-25-2021, 03:23 PM   #8
eystein
eystein's Avatar
The bumper seems to high, which I believe to remember was the case with what I could buy from most of the ordinary suppliers. I believe that I finally bought the correct height bumper from Bob Drake
eystein is offline   Reply With Quote
Old 03-25-2021, 05:33 PM   #9
Oldbluoval
Oldbluoval's Avatar
Adjusting height is very common....almost always
Oldbluoval is offline   Reply With Quote
