08-27-2018, 11:58 AM | #21 |
Re: Intake Manifold differences
2 of my 21 stud engines have cast alum intakes , one is completely burnt thru the exhaust .
The heads on both have the 46 cast date code . It's located on the underside of the head , near the intake ( top ) and is visible if you use a mirror between the intake and cyl head . One engine is flat top std bore steel Pistons the other is domed and .040 over . 2 sets of heads with the 46 code , 2 different combustion chamber designs . Both are LB |
08-27-2018, 01:22 PM | #22 |
Just for grins, I looked at the cylinder head chart in the green bible. It shows that they made the 40-6049-B iron heads for the 33 thru 36 and 68-6049-B iron heads for 1936 but in the "replaced by" column it shows the 68 series with the B suffix iron heads for all the early water pump in head 21-stud engines. Those part numbers 68-6049-B & 68-6050-B were the final replacements for all those old engines. I have no idea when they quit producing them but 1946 would have been the 10-year mark that most manufactures go by for replacement part production limits.
