Old 11-04-2017, 03:21 PM   #1
Burt Lake Barn
Burt Lake Barn's Avatar
Default Rear wheel hub assembly question.
I have replaced the seals and cleaned/re-greased the bearings on my 1941 ford hubs. Has been apart for a while during a complete overhaul of the rear end. During reassembly, I found six very thin washers that appear to have been used as a spacers. They are about .006 thick, have an OD of 1 5/8 inches and an ID of 7/8 inch so they will only slide down an inch or two before the axle shaft gets too large. So I'm thinking they may have been installed under the outer axle nut??? Any experience with this????
Burt Lake Barn is offline   Reply With Quote
Old 11-04-2017, 08:14 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Rear wheel hub assembly question.
Perhaps the inner threads have been stripped and they were trying to use better outer threads.
Russ/40 is offline   Reply With Quote
