Old 05-03-2015, 11:09 PM   #1
Garychinook
Question 31 Rdstr rear inner fender panel replace
Howdy folks,
Haven't worked on the Model A for maybe a year or so. Work/family stuff. I am going to try and get back at it with this project.
I am replacing the rear inner fender panels on a 31 Roadster and was wondering if anyone has any photos that might depict 4 things; the spot weld pattern front to rear along the bottom, the actual width of the horizontal lip along the very bottom, the two rivet heads/tails in the middle of the panel to the floor brace and the larger rivet heads/tails more at the lower aft corner of the panel.
This is an effort to undo a previous so called restoration that welded instead of riveted no spot welds on an older repop panel.
Gary
Garychinook is offline   Reply With Quote
Old 05-05-2015, 12:55 AM   #2
Garychinook
Default Re: 31 Rdstr rear inner fender panel replace
Well, I thought I'd try this again. If no one has any photos a brief narrative will work. I'm going to the trouble of redoing this badly done previous attempt at a restoration I want to get it pretty close to the original process. Querky that way sometimes.
Thanks, Gary
Old 05-05-2015, 01:14 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
It just might be that none of the almost 100 people that have looked at your post has their car apart to supply pictures/measurements for you. It is driving season as you know.
