03-20-2021, 05:35 PM | #1 |
Model A decklid/ rumble seat lid bumper
I usually do well with this sort of item, but this one has me defeated. How in the world do you install these?
03-20-2021, 05:43 PM | #2 |
Re: Model A decklid/ rumble seat lid bumper
Coat the end with a dab of liquid dishwashing soap, and you have to twist and push real hard to get those on. Your post reminded me of the difficulty I had installing the same bumper years ago.
Kevin |
03-21-2021, 07:29 AM | #3 |
There is a lubricant in the ladies section at the pharmacy that is good for many things! This is one of them! Wayne
03-21-2021, 08:33 AM | #4 |
They are a real challenge to get in. Then you may have to grind them down if the lid sits to high.
03-21-2021, 10:14 AM | #5 |
🤣 or perhaps just glycerin.
03-21-2021, 12:24 PM | #6 |
03-23-2021, 07:02 PM | #7 |
Thanks for the suggestions. I got all 4 in. lube and twist, and press ( al lot of each). I got some assist from a ratchet clamp that I use for carpentry projects, that helped a lot. Lid fits great now.
03-25-2021, 03:23 PM | #8 |
The bumper seems to high, which I believe to remember was the case with what I could buy from most of the ordinary suppliers. I believe that I finally bought the correct height bumper from Bob Drake
03-25-2021, 05:33 PM | #9 |
Adjusting height is very common....almost always
