05-17-2010, 09:45 PM | #1 |
Info on 1950 Ford dual exhaust conversion
Any tips on converting my 1950 ford to dual exhaust while retaining the origional stock manifolds? I want to use smithey's mufflers . Need advice as the length of mufflers and source of the various pipes. Any other info would be of help.
05-18-2010, 12:51 AM | #2 |
Re: Info on 1950 Ford dual exhaust conversion
If you want to retain the original ex. manifolds then the only solution I can think of is the way we all did it "back in the day" which was a U tube that went up from the front of the manifold and then back and then down around the shifting and clutch mechanism. Sounds complicated but it worked great for years.
As for muffler length, I like loud and so for me the shorter the muffler the better. Your best source might be your local muffler/exaust pipe shop where they may construct your pipes to your specs for less money then the mail order pipes. Keep your tubing to 1.75 in. or less for best sound. |
12-11-2013, 07:32 AM | #3 | |
Thanks |
12-11-2013, 09:49 AM | #4 |
I will also looking to duals on my '50 cc in the next month or so. When I first got the car, I noticed that Drake sells the left manifold. I wanted to find a source for the lead out pipes, mufflers (American made) and tailpipes. I called Waldron and they said they could supply all the pipes leading from the cast manifold, including my choice of one or two piece tailpipes.
Has anyone had experience with Waldron? Howard |
12-18-2013, 08:31 PM | #5 | |
12-19-2013, 01:00 PM | #6 | |
Thanks for your input, but if you read my previous posts you would see that I'm looking for routing the connecting pipe from the tubing exhaust (Drake) to the muffler on a 40 ford tudor. I think you both are referring to a car in the 50"s, and don't believe the routing thru or around the frame is the same. I invaded someone else's Posting with my similar problem, and for that I'm apologizing. |
12-26-2013, 01:23 PM | #7 |
I have received the Drake LH manifold and am waiting for the pipes from Kepich. I still plan to post details of installation but, I have a question regarding outlet size of manifold from Drake. I thought it looked a little small, so I measured the outlet diameter. It measures 1-3/8". The front outlet on the stock, front outlet, LH manifold measures 1-5/8". Should I have a concern with restriction? Does anyone have a Rooney manifold they can measure for comparison? Comments please.
Thanks, Howard |
12-26-2013, 02:21 PM | #8 | |
05-18-2010, 01:42 AM | #9 |
Jack 99,you not gonna be happy with the Smitties,they rot out quick and are made in China.Very poor quality. Buy Brockmans Google them. ken ct.
05-18-2010, 04:15 AM | #10 |
According to the folks at Smithies, they're made in the US, not china.
05-18-2010, 06:01 AM | #11 |
You need a left manifold like this...
05-18-2010, 06:13 AM | #12 |
YOU COULD TRY RED'S HEADERS, here is a link with his info...
http://reds-headers.net/index.php?ma...roducts_id=171 |
05-18-2010, 06:45 AM | #13 |
You might check out Porter Muffers too, they're heavy, steel vs fiberglass packs, and are US made. I put a set on my Yblock and they sound great, and with a lot of bark when I get on it.
If you can't find one elsewhere, Clark up at West End Welding in Minnesota (home of Porter Mufflers) might be able to help you out with the correct crossover/tube to use with your original manifolds too. Maybe give him a call? He's very helpful. I think his phone # is on their website. He had a set of NOS Belond headers for my 292 so I got them along with a pair of mufflers from him. I wanted to also get a set for my next project ('47 superdeluxe) but he didn't have any flattie headers left. He put a video and sound of dual porters on a '48 flattie on his website, you might want to check it out. Here's the link to Porters: http://www.portermufflers.com/ And here's the YouTube video of '48: https://www.youtube.com/watch?v=UjNYSbdq4Ek |
05-18-2010, 06:32 AM | #14 |
I have one of these and a pair of 22" Smithy's I would be willing to part with, also the right hand side exhaust manifold with a block off plate installed.
50 Tudor Sedan 31 Model A Coupe |
05-18-2010, 06:47 AM | #15 |
I bought a set for my 51 sedan back in the 80s from ARASCO and it mated to the stock manifolds. The left pipe came out above the frame then swept down to the chassis. Everything fit well. The set came with glasspac mufflers and sounded good. It's still on the car with a new owner altho some tailpipe sections have been replaced.
05-18-2010, 08:24 AM | #16 |
My Smittys rusted out in 4 years and 5000 miles on my "50.
05-18-2010, 09:39 AM | #17 |
Suggest you contact Pat Rooney ([email protected]) he sells the left side cast iron manifold.
12-12-2013, 08:30 AM | #18 |
Been running the cast drivers side manifold JDL has pictured above with a block off plate on the passenger side manifold inlet and dual Smithys on a 51 2 door since 2006 with no problems. There is no sign of rot in the mufflers and they sound great, has a slight rumble and a good mellow tone with minimal cackle. In my honest opinion the cast drivers manifold kit is the only way to go if you want to run true duals and keep a stock looking appearance. At first glance it blends right in and looks factory, they fit perfect and you don't have to worry about them lealking unlike headers. Bob Drake sells the kit (drivers cast manifold and passenger side inlet block off) for I believe in the $100 range.
Hope my .02 helps Dennis |
12-12-2013, 08:56 PM | #19 |
Dennis, What did you use for the left exhaust pipe? I sent an inquiry to Drake today asking if they supplied the pipe. There answer, "have an exhaust shop bend up the pipes for the left side". To me that takes the DIY out of the project. I have another inquiry into Waldron about an exhaust pipe for the Drake manifold. I know they sell the old 'loop type' pipe with a complete kit and they also sell all the pipes to hook up to Fenton cast headers. We'll see. Red's has complete kits with steel headers, I may go with them. I like one stop shopping!
12-13-2013, 04:39 AM | #20 |
HCO41, why can't the pipes (DIY or shop bent) be hooked up to the stock left side exhaust manifold?
