11-07-2020, 09:44 AM | #1 |
Waterless coolant
Does anyone use Evans (or any other) waterless coolant. Is it any good for a model A? How well does it work? I'm interested because of the corrosion protection it might give to the model A cooling system.
11-07-2020, 09:55 AM | #2 |
Re: Waterless coolant
I have used similar products! The best over the years I use NAPA 1300 Rust Inhibitor,with Distilled water!!
www.whidbeymodelaclub.com |
11-07-2020, 10:13 AM | #3 |
Some people use it because it has a higher boiling point than antifreeze. I don't know what advantage it would be unless your cooling system is marginal.
11-08-2020, 02:58 AM | #4 |
I use it. No water = no rust. I do have a pressurized, closed cooling system.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
11-08-2020, 05:13 AM | #5 |
11-08-2020, 03:31 PM | #6 |
