Old 12-31-2020, 07:09 PM   #1
wright-47
Default Head bolt sealant
What have you guys found to be the best sealant for the head bolts to block on a 21 stud. I tried thread sealant paste but it didn't work. Thx and Happy New Year
wright-47 is offline   Reply With Quote
Old 12-31-2020, 07:25 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Head bolt sealant
I have used 3m weatherstrip adhesive for longer than I can remember on dozens of not hundreds is engines to include flatheads, small & bb Chevy. Never a leak or issue.
Old 12-31-2020, 07:29 PM   #3
V8ER
Permatex no. 1
V8ER is offline   Reply With Quote
Old 12-31-2020, 07:41 PM   #4
wright-47
Thx. Pematex was my next option
Old 12-31-2020, 07:44 PM   #5
1948F-1Pickup
1948F-1Pickup's Avatar
Permatex #2 on headbolts.
1948F-1Pickup is offline   Reply With Quote
Old 12-31-2020, 07:48 PM   #6
51504bat
51504bat's Avatar
X2 on number 2
Old 01-01-2021, 08:30 AM   #7
chap52
chap52's Avatar
Permatex Thread Sealer part #80632 Available on Amazon in both the 4oz jar and 6ml tube.
This is a Teflon product that I have found seals well and does not harden. . . Chap
Old 01-01-2021, 09:30 AM   #8
19Fordy
19Fordy's Avatar
Buy at O'Reilly's. I have also used Non -hardening permatex as it works great also.
Old 01-01-2021, 11:53 AM   #9
rotorwrench
rotorwrench's Avatar
I used to use Aviation Permatex and just dip the threaded tips in the can but there are likely better sealers now days. This also keeps the bolt tips from corroding which allows for easier removal during maintenance.
Old 01-01-2021, 12:47 PM   #10
1948F-1Pickup
Comparing the MSDS on those shows they're pretty similar.....
Old 01-01-2021, 01:54 PM   #11
Bored&Stroked
Bored&Stroked's Avatar
I use ARP Teflon stud/thread sealant - comes in a tube.
https://www.jegs.com/i/ARP/070/100-9904/10002/-1
When I install the studs, I do not put water into the engine for at least a day - just to give it some time to seal the threads a bit. Also, I use a thread chaser (not a tap), on the block threads - to get as much rust and old crap out of them as possible.
This method has worked for me on countless flatheads - with both studs and bolts.
