Old 05-16-2014, 07:46 PM   #1
1930 coupe
Default
1930 coupe is offline   Reply With Quote
Old 05-16-2014, 11:58 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Steering box leak
I never had the problem. Not being in front of a car, I remember the tilt of the steering assy such that the fill is below that point. Like i said I'm not in front of a car so I can't verify.
Old 05-17-2014, 07:12 AM   #3
Growley bear
Housing cracked?
Growley bear is offline   Reply With Quote
Old 05-17-2014, 07:22 AM   #4
Mitch//pa
as mike mentioned when the box is mounted in the car it will not leak due to the angle
Old 05-17-2014, 08:03 AM   #5
Growley bear
I guess I misunderstood the question. Are you filling the box on the bench and laying it down on its side? set it up to it's approximate position and angle in the car first then check for leaks.
Chet
Old 05-17-2014, 08:34 AM   #6
Joe K
Joe K's Avatar
I can see how it might happen.
Perhaps this like the petcocks on a Model T? Fill until the upper petcock lets it leak out?
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 05-17-2014, 05:50 PM   #7
Gunmetal blue2
Gunmetal blue2's Avatar
Gear boxes 7-tooth takes 7 3/4 ounces, 2-tooth takes 4 1/2 ounces of 600 W.
Gunmetal blue2 is offline   Reply With Quote
Old 05-17-2014, 05:59 PM   #8
bluzrocker
bluzrocker's Avatar
Tx for the amt to add to a two tooth...now I wont have a mess while waiting for it to stop leaking to no leak level
bluzrocker is offline   Reply With Quote
Old 05-17-2014, 10:35 PM   #9
Mike V. Florida
Should not leak at all.
