05-08-2011, 07:10 AM | #1 |
No spark..makes..no reason?? 35 v-8
Hi gang, I am flabbergasted..I have new wires, new skip coil and dist..new setof champions but cannot get spark..
-I tested coil, full 6 vlts applied, and when dragging the "pigtail coil" to ground get a weak arc from carbon.. -Test light and power to dist..indicates point operation off/on /off /on.. -caps seated nicely, flush in housing.. -carbon new and clean.. -Piggy tail spring not grounding on case or retaining ring..I gonna have skip recheck my coil?? but he has done v-12 coils for me with awesome results.. I dont have a heier machine..just ohm meter and test lite.. |
05-08-2011, 07:20 AM | #2 |
Re: No spark..makes..no reason?? 35 v-8
Zeffer
If you don't have a dwell meter re-check the point opening gap with a feeler gauge. I hope this helps Kojack |
05-08-2011, 08:12 AM | #3 |
My suggestion is to send the complete to Skip and have him set it up and test it on his machine. Works for me ! I carry a complete set up on trips.
05-08-2011, 09:24 AM | #4 |
Not that familiar with the '35. Did you check the condenser? Just because things are new does not = good. I had the same problem and it was a 'new condenser'. Took one of one of my grease covered spare engines and it worked.
Henry Ford designed the flathead without the aid of a computer. |
05-08-2011, 10:57 AM | #5 |
Condenser?
Good place to start, but not simply if it's good or bad. It must be grounded to the engine. The '35 is a bear to get to all the distributor bolts. If you do not get the upper passenger side bolt tight and establish a good ground for the condenser attachment, you may not get a spark. New paint on the block ... a little clear on the distributor housing ... loose bolt ... Easy things first.
"Remember that when it comes to intelligence, half of all of us are below average." |
05-08-2011, 11:08 AM | #6 |
05-08-2011, 03:28 PM | #7 |
is the rotor turning?
